Trailer hitch on lowered truck
Discussion in 'Exterior/Body' started by Justin Danger, Feb 17, 2017.
  1. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Hi friends,
    I'll be moving in a couple weeks, and am looking into renting a trailer from Uhaul. I don't have a hitch set up yet, and was wondering how they work out on lowered trucks. I do have extra load rear shocks, but am wondering if the height will be a problem. Will it put too much toe angle on the trailer? will it hit the ground going over bumps, curbs, rough roads?
    thanks!
  2. Justin Danger
    Bay Area Peninsula
    oh, and my drop in back is 3" blocks
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I've seen drop hitches flipped upside down on lowered trucks to help level out trailers...
    In the end, it depends on how the trailer is loaded...it needs to be balanced over the axle of the trailer.
  4. Justin Danger
    Bay Area Peninsula
    cool deal, i was wondering about flipping one of those. thanks for the tip
  5. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Flip your drop hitch or get one of those adjustable hitch setups. You could also likely use one of those "double hitch" adapters and use the top hole, but less connections is always better.
  6. Steve M Clark
    Steve M Clark Member
    Waynesboro Virginia,Shenandoah Valley
    1980 SR5 short bed
