Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. DROPT
    DROPT Addict
    Whales Vagina
    its still sitting helplessly in the garage. awaiting a timing cover from joeynational
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    ohh shoulda bought mines :)
  3. loluxprogress
    loluxprogress Enthusiast
    VIC, Australia
    1994 Toyota Hilux 22R
    was driving to work this morning when bottom end knocking noise started. Didnt make it to work, engine gave out. Now its raining late afternoon and Im waiting on a flatbed towtruck from work to get me.
    Looks like itll be getting an engine swap.
    home.
  4. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Today i learned that my engine has no compression.
  5. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Today I installed my electric fan on my 22re with an automatic temp sensor and it works perfectly! :D
  6. V8_TITAN
    Tampa Fl
    89 std cab
    dang that sucks, you have a 22r or the v6 ??? what motor are you planning on putting in it ?
    how bad is it ?
    sounds like fun, what kind of fans did you use
  7. IronNam
    everyone's having bad luck lately...
  8. oahu grown
    Hawaii
    92 Extra Cab
    V8, i dunno. Tested #1 and #2 and had no pressure. Dunno what caused it. Also a continuation of my other thread about dying out on the freeway. Im thinking of just yanking this motor and dropping another one in so i can get it running, cause i need a car and then just working this one slowly on the side.
    What are the most common synthoms for no compression? Bent valves? Bad piston? Seals? I know could be just about anything engine related.
  9. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    you just gotta take her apart and see what killed it, crazy things happen inside engines, bent valves, holes blown in pistons, holes in the block, blown head gasgets...who knows, just gotta open her up and look.
  10. V8_TITAN
    Tampa Fl
    89 std cab
    yeah ohau, take it apart and figure it out, and when you say no compression you mean zero ? I find that a little hard to beleive from having a running motor to zero compression.. unless you bent a valve or the a hole through the piston.. maybe you did the compression test wrong ? let me know if you want to order any parts for you and ship it usps flat rate to save you some coinage, Ive seen how much sht is over there and its rediculous.
  11. oahu grown
    Hawaii
    92 Extra Cab
    Yeah absolutly zero from #1 and #2. My cousin came over with his tester. The thing you screw into the spark plug hole and it read nothing. Also did the finger test and nothing as well.
    Right now im trying to find another motor. Hopefully i can find a running one and swap it right in and then tear this one up on the side. Being completely broke is a major factor though.
    And yeah i dunno what happened. I guess motors just die sometimes.
    Oh and titan, thanks for the offer. Definatly a money saver right there.
  12. loluxprogress
    VIC, Australia
    Its got a 22r. Im thinking of the holden commodore V6, but will cost me close to $2000aud for conversion kit/parts. my mate has an 84' 22re he said i can rebuild it, would it be any better than a 22r?
    a 2jzge would be wicked. im not sure whats involved in it though.
    so, Lux is home and sitting in yard, might go remove seats and work on subbox.
  13. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    cut the rest of my bed floor out need to order some steel now
  14. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    put new speakers in the dash (alpine type s) and cut the stock exhaust short so it didn't stick out like a sore thumb
  15. V8_TITAN
    Tampa Fl
    89 std cab
    hell yeah I got those in my dash, best thing since fried rice.
  16. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    yea and i have a set of 6" pioneers i put in the doors a couple weeks ago, sound is clear as day now i just need a bazooka tube and im set
  17. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    @v8 Titan
    teh fan i used was part #3700 from hayden which is a 16 in 1400 cfm fan
    And hayden 3651 automatic temp sesnsor/relay
    The main reason i got this fan setup was because it has a lifetime warranty :cool:
  18. andrep6810
    andrep6810 Member
    Miramar, Fl
    94ext 2jz
    I picked up a 60 -1 turbo to replace the one that came with the truck.
  19. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    2 days ago I got pulled over.
    Cruising the ghetto hood 4 blocks from my house 10 pm on a side street, a cop is driving the other way with no lights on. I pass him and he flips a U'ey and throws on his lights.
    Show him my ins. and license and he runs it and lets me go. :shrug: :shrug:
    He said my tail light lens is cracked. No ticket though.
  20. andrep6810
    andrep6810 Member
    Miramar, Fl
    94ext 2jz
    My turbo is smoking, so ready to jump off a cliff.
