This past weekend
Discussion in 'Off Topic' started by TRUCK ACTION, Mar 28, 2023.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So FFF was a great show as always, I left Friday morning @ 5 we hit a bad traffic jam at Altamont Pass where 5 lanes dropped to one ,we were in the middle. Took a Hr going uphill & a little less going down.
    Had to ride the clutch & hold rpm's up a little..
    414 miles latter & 2 gas stops latter ( I gas up @ 1/2 a tank around 6 gals always), a seem we lost the starter, a grinding noise & no engagement of the starter., call ahead to Bull City AZ ,found a shop that said they could do the install of a new starter & had one, they close at 3 , talked them into waiting if I were to be late. So from 40 miles south of Barstow Ca. to Bullhead city, a distance of 163 miles we went at between 85 & 100mph.
    UPON inspection they found the the steel outer ring on the aluminum flywheel has separated ( heat from clutch ) & was bouncing around damaging the all in there!
    They could do the repair , but were closed over the weekend!
    So we made the show but no truck, & had to stay tough Monday. A stock steel flywheel & stock clutch kit , through out & pilot bearings also, $1,400!!
    Left the shop @ 4 pm Monday, got home at 1:40 am , 595.7 miles . 1,191.4 miles total around trip!!
    One hell of a road trip!
    Perkolator and jetas like this.
  2. jetas
    What a bummer!! Luckily it wasnt a more catastrophic failure and you were able to drive home
    TRUCK ACTION likes this.
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    We were very,very lucky that the steel ring while bouncing around didn't break apart & come though the truck or lock up the engine which would have de stored it!!
  4. jetas
    This is making me want to pull my flywheel and inspect it
  5. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Should also consider this the amount of times I've stalled my truck up to now... :thinking:
