stretched tires
Discussion in 'Wheels/Tires' started by Comrade_Charlie, Feb 23, 2010.
  1. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    Any one do stretched tires on stock rims? i have a 73 and figure I want to do a mild stretch nothing crazy. just for more clearance and looks. Any one done this, right now on my Z I have 225 on a 9 inch wheel and its an ok stretch but I want more on my truck, It might have 7 inch wheels. id post in the 75 and older section but its dead.
  2. jetas
    Everything ive heard about stretched tires is either "looks cools" or "its extremely unsafe and youre a dumbass" I like the look of a mild stretch. but 225s on a 9" wheel is alot of stretch.
    If the wheels youre guna run are 7" i have no idea what tire size u wud use. seeing as a 205 is already a bit stretched
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    depends what series tire you run. i have 205/70/15s on the front of my dodge and they are 15x7s. its not a streth, its got a slight bubble to it. and if you mean you think the stock rims are 7" wide, and there are OEM stock...they are 5" wide. nothin but a bike tire will stretch on that. lol.
  4. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    if you have (what im assuming) 15x7 you are looking at the minimal of a 195/50 or 60 ........ a 185 if thats even a possible size combo in a 185/50 or 60 series tire.
  5. jetas
    stretching the tire on a 7" wide wheel is guna be a b!tch. Just cuz of the width itself. now if it was and 8" then id say DO ET!!!
  6. Comrade_Charlie
    1973 Hilux
    I just assumed they were 7inch, I have my own tire machine so ill pull them off one day.
    225 on my 9inch wheels isnt bad, ill snap some pictures of it.
    And im on some drifting forums/nissan forums, and they never really say its unsafe except for you have lest tread on the road. It might be unsafe on a 3000-4000lb car like a big supra or something.
    And thanks for the replys!
  7. SD YOTA
    your wheels should have the size stamped on the back side of the wheels somewhere. clean em up and take a look.
  8. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    im running a 215 60 14 on my stock 77 wheels with no issues
  9. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Also gotta make sure the tire meets the right weight requirement for the truck.. Ive heard of people doing that, but using a smaller tire which wasnt rated at the cars weight.
  10. Comrade_Charlie
    1973 Hilux
    Ill probably just go with what I can find, if yall say it is this small Ill just get 205. Im not trying to look for anything under 200, unless a 195 pops up.
    Thanks
  11. standardbyker88
    lynnwood, wa
    i have 195/65s up front. no stretch on my 14x5s but they have a good look to them.
  12. IronNam
    a slight stretch should be fine. a major stretch, eg. 205 on a 9 inch rim.... is what i consider dangerous.
    have you seen the stretch on those VW's in their scene? scary looking.... i consider unsafe.
    but as long you don't go too far, you should be fine playing in the safe zones.
    9inch rim + 225's-235's-245's should be sufficient
    8inch rim + 215's-225's
    those are some i could think of.....
    The reason the drifters in Japan started to stretch tires is to create a stiffer sidewall to initiate drifts easier, kicks out the rear easier.
    You may be thinking... I dont wanna slide around, but that's only if your stretch goes far.
  13. SICK TOY RAMBLA
    SICK TOY RAMBLA Member
    90' DLX Single cab
    Like this??
  14. jetas
    Thats the unsafe stretch i was talking about. Doesnt even look right
  15. thundering02
    thundering02 Addict
    Fenton 63026
    That looks hella retarded especially since they cut up the car to be a "truck"
  16. SD YOTA
    i actually think that is originally a truck........ but its a jdm or other market...... not american. looks kinda sick imo :thinking:
    here's my stretch........ 205/50/16 mounted on 16x8 on the rears and 205/50/16 mounted on 16x7 on the fronts........ they are staggered wheels too.
    Shot with X400,D580Z,C460Z at 2010-02-25
  17. red_d
    red_d Member
    San Jose, CA
    93 2wd Pickup
    im running some 195-55-16 on my 16x8 starions with not problems
  18. SICK TOY RAMBLA
    90' DLX Single cab
    2/3 drop. 5zigen Rims.
    Front: 17x9 wrapped with stretched 235/40/17's.
    Back: 17x10 wrapped with streched 245/40/17's
  19. IronNam
    A slight stretch...
    that Nissan's stretch is overkill lol
    but i like it?
  20. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    yeah both those cars and that one truck looke very unsafe. they look like lowrider wannabes like they should be on 12 inch daytons or something. lol. they just look retarder too the other pics you guys have put up look ok though.
