Shifter bushing
Discussion in 'Engine/Drivetrain' started by Ivey, Dec 5, 2018.
  1. Ivey
    Ivey Member
    Portland, OR
    1976 Toyota Hilux
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I have a 88 with short trow shiftier from LC those use there's which are different from the stock parts,but look the same.
  3. fred heath
    fred heath Enthusiast
    Raleigh, NC
    Try marlin crawler. They have 2 different sizes. I ordered both and used the one that fit (don’t remember exact one).
  4. Ivey
    Ivey Member
    Portland, OR
    1976 Toyota Hilux
  5. jetas
    When i had the L43 on mine i swapped the bushing, made a big difference. Never actually drove the truck with that tranny tho.
    Ivey likes this.
  6. Perkolator
    Perkolator Addict
    Placer County
    75 Hilux, 93 XCab 4wd, 02 Land Cruiser
    In your search did you come across one for a w50? My shifter is super sloppy
  7. Ivey
    Ivey Member
    Portland, OR
    1976 Toyota Hilux
    So if you go to that shifter bushing marlin crawler link they have two bushings, one for the L43 and another for other transmissions. That will probably fit your w50 shifter (the other one not the L43 one). You don't need the rubber bushings but you do need a shifter seat. MC also has those but I'm not sure which one you need for the w50. The MC site actually has some really nice guides based on your transmission:
    https://www.marlincrawler.com/transmission
    Looks like there are a couple w5x transmissions listed but that should get you going.
    Edit: here is the link for the seat: https://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-seats
  8. Ivey
    Ivey Member
    Portland, OR
    1976 Toyota Hilux
    Well that was a bust. I pulled off the shifter to find the PO had replaced the bushing already. Oh well win some, lose some. Now on to the rear axle seal.
  9. fred heath
    Raleigh, NC
    If you’re talking about the seal on the axle shaft(s) you better plan on buying new bearing(s) as well. There’s no way to replace the seal(s) without doing the bearings at the same time.
