So Im in the process of rebuilding my truck and I was looking for a roll pan. I found one local for a tacoma. My question is would that one work on the 89-95 bed. From what I can tell the rear of the beds look the same, and should roughly the same width. Anyone have an idea if it would work?
I think the tailgates are a direct swap. Obviously they look different but the roll pan might probably be different. Hell just get a grant kustoms rollpan
The rollpans are the same width but the height and profile are different. You can adjust the profile at each end to match the older bed but the center will still retain the tacoma profile. I would just spend the extra cash and buy a pan that is built for the truck.
Honestly, I bought mine from Grant I think but it would've been alot cheaper and very little more work to make your own . Just my .02. Ended up having to fit it quite a bit for it to be perfect and need a couple small pieces of filler plate where it didnt match up perfectly.
