question about radiators?
Discussion in 'Maintenance/Repair' started by CUCUY, Aug 16, 2013.
  1. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    1983 Toyota SR54x4 Mojave Edition-Black Package Shortbed Sport Truck
    All of my radiators use stock frames / mounting (32 Ford, 50 Mercury, 1983 Toyota, etc.) with custom cores and were built by a local radiator shop (Madenfords, Fleetwood, PA). The deuce and Merc use custom fan shrouds with Ford Taurus fans and the Toyota uses the stock fan shroud with the Ford Taurus fan.
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    The Taurus fans are great. Two speed and about 16" I think. Did you wire low to a constant power and high to a thermostat switch and/or toggle? That's my plan. Always on low, high when I need it.
  3. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    My electric fan's low speed is wired to a Ron Francis Wire Works temperature sensor and a high amp relay circuit that incorporates an Auto / Man toggle switch and my my electric fan's high speed is wired to my A/C Amplifier and a high amp relay circuit that incorporates an Auto / Man toggle switch. My engine's oil cooler electric fan is wired the same way.
  4. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    can you draw up a wiring schematic for this please?
  5. standardbyker88
    lynnwood, wa
    Sounds pretty simple. Lots of ways to run it. I like that.
  6. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Just so you know I ordered a all aluminum 2 core for a pickup/4 runner v6 off eBay for $160, I'll let you know how it fits/mounts when I get it.. figured just getting a new(read not clogged haha) all aluminum one would help cooling a lot!
  7. standardbyker88
    lynnwood, wa
    Awesome. Either the upper or lower holes will work then redrill the other pair. Make sure you can close the hood before you drill ya know. And be prepared to extend the lower radiator hose. Ill get pics of mine if you can't find any on the build thread.
  8. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    :waytogo:
  9. first80toyota
    Pacific Northwest
    '77 Hilux
    I put my radiator in yesterday/today and it actually fits quite nice! I also switched to a 180 thermostat instead of a 195:cool: I havnt really driven it yet, did about 10 miles total, maybe 2 of them on the freeway. Didnt hit 190*!
    Heres a couple pics for you!
    It doesnt hang much lower then stock, maybe an inch?
    Ended up lengthening the lower hose 5ish inches, had to weld to short pieces together and i think i have a pin hole... The fan is about 2" away from the radiator so no worries there.
    Heres the one I bought: Sillatoyota 1989 95 Pickup 1988 91 4 Runner 2 Row All Aluminum Radiator | eBay
    I actually think its a 3 core, but eitherway, its bigger then the stocky
  10. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    NNNIIIIIIIIIIIIIIIIIIIIICCCCCCCCCCEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!1111111
    :bowdown:
  11. first80toyota
    Pacific Northwest
    '77 Hilux
    Between the new radiator and lower temp thermostat I haven't hit 190*! I think it was worth it!
  12. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    awesome, will definately be doing this upgrade real soon!
  13. The Jewish Guy
    The Jewish Guy Veteran
  14. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
