Need ecu pinout for 94 22re
Discussion in 'Engine/Drivetrain' started by Xs5875, Dec 6, 2014.
  1. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    I have the grey 2 connector ecu. Need the pinout for it. Online all I can find is the 3 connector.
  2. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Like this?
    [​IMG][/URL][/IMG]
  3. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Yeah but that's a 3 connector. I found it anyway thanks.
  4. 1lowSr5
    1lowSr5 Addict
    In the garage
    Sweet, was just going to repost I found one too haha
  5. Litneon
    Cocoa, FL
    94 xtra cab
    What are you working on?
  6. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    I de emission and have the harness off and am de pinning the un necessary wires.
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    So. I know the injector plugs are blue...but I have 3 blue and 1 grey? Anyone else's that way? It has not been repaired or rigged up its factory connected....and which cylinder is the grey one on if you have it
  9. Litneon
    Cocoa, FL
    94 xtra cab
    I also have a grey connector. It's on cylinder #1.
  10. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Thank you sir
  11. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Post your 2 connector pin out been looking for one
  12. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Hey Litneon. I really doesn't matter..but it intrigues me. How does the firing of the injectors work? I understand they are always hot and grounded by the ecu in sequence. But what tells the ecu when....
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Here's the one I have straight from the service manual.
  14. REDZ
    REDZ Enthusiast
    if u open the ecu u will see the names writen below the pins on the ecu board aswell
  15. Litneon
    Cocoa, FL
    94 xtra cab
    The injectors aren't fired in sequence. They are batch fired using the tach signal from the igniter.
    The funny thing is, there are two output pins for the injectors that seem like they'd fire in pairs, but then the harness is soldered together up from the ECU.
