My Silver Toy
Discussion in '1989-1995 Build-Up/Project Threads' started by toy_spd, Apr 20, 2011.
  1. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    what happens when your bored? you do a ball joint flip that's what!
    Top, still wet from the cleaner spray, lol
    Bottom w lock washers as spacers
    end result:
    I ended up turning the torsions up 5 threads, about 1/4" of threads, she was to low and I had no turning radius :verdict_in:
    So the fender is right above the tire.
  2. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Got pics of the hanger mod, wanna do mine to.
  3. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    here is a picture of the mod,
    up 1.25" and back.5" from center
  4. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    So does the tire sit further back in the wheel well now??
  5. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    yeah, .5" unless you measure it your not going to know.
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    how much of a drop does this mod give you?
    i know there is a write up somewhere but i havent been able to track it down.
  7. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    over an inch
  8. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    you should to a write up on this!!! im interested in this mod.. hoe long did it take?
    my only question is, if it moves the rear end back 0.50" back then what stress is put on the drive line if any?
  9. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    I researched this mod online. some people can go 2" up on the Nissan's, its been around for some time. I didn't read about any issues people were having. I did read where some trucks needed a new inside plate to be welded on.
    I could probably do this in under an hour. It took me longer because I did not have the right size drill bit so I went out and bought one.
    you just make a template, take your measurements, check your measurements, use a center punch to mark your new spot, pilot hole, enlarge it a bit and then enlarge it some more and you're set. move on to the next one, 4 holes later, bolt up and go.
  10. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Installed Monroe air shocks in rear ftw. now I can load things up and the truck wont sag.
    right now my street bike is on it and the truck is leveled out. ftw.
  11. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    did you measure how much you got on the BJ flip? Curious if its actually 1"..Im doing new BJs next weekend on my truck.
  12. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    The measurement difference I got was 1.25" of drop with the ball joints flipped. The lock washers I used as spacers are .25". Its simple and free, can't beat that, lol
  13. Bradthreee
    Bradthreee Enthusiast
    Palmdale, Ca
    1990 xcab
    Love this thread! Thanks for posting!!!
  14. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Come on man !!!!!!! You know better then not post any pics of your upgraded airshocks.
  15. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    got the carb rebuilt. runs way better now!:bowdown:22R
  16. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    if you do teh hanger mod it is good idea to shorten the shackle
  17. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    Damn, you did more modifications in 18 months than most do in a life time. :applause:
  18. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
  19. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
  20. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    20 mins to tuck....
