my 86 yota (draggin doors) 56k warning
Discussion in '1984-1988 Build-Up/Project Threads' started by burnzya, Nov 9, 2008.
  1. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    you don't have to chop the rear window. after i chopped mine i regretted shorting the window. if you make the proper cuts you can drop the full size window. it will just take up that couple of inches in between the bed and the stock rear window. it also make the chop less noticable.
  2. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    no, tempered glass has been heat treated by cooling it in a way that the inside of the glass pushes out, and the outside pushes in making it very hard and stable,till you hit an edge, that's the weakness.
    If you sand to much it will pop, and if you try and cut it, it interrupts the pressure balance and it will pop.No way at all to change the size of a tempered part.
  3. lownloud
    lownloud Toyotaholic
    Plains, Montana
    . . . knowing that price is a downfall, if you dont want a lexan rear window, cantcha just make a template and have one made?! I order tempered glass alote, but its mainly for flat surfaces, none with slight or curved surfaces . . .
  4. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    rear glass is actually a fairly easy fix .. the reg cab window is much smaller , and I could actually put in a new rear wall to accomadate the smaller glass ..
    it's the side windows that are the problem for me .. I have checked into having some custom made .. and they want 400.00 ea. so .. I just might go that route .
    sorry , not trying to "scoop" your post ..
  5. burnzya
    bodied 73 hilux
    no problem, i couldn't find crap on choppin a yota until after i did mine.
  6. burnzya
    bodied 73 hilux
    worked on those pesky bed seams today, just about got them all welded up, i'll finish them later tonight.
    my brother preppin the seams for welding.
    started by putting a tack every inch or so.
    then welded in between every other tack.
    then finish welded and grinded the area
  7. burnzya
    bodied 73 hilux
    and a few of it sittin outside while we worked on the bed, i love watching people slow down and stare as they drive by.
  8. lownloud
    Plains, Montana
    Soo very pimp man, awesome is the only word I can come up with . . .
  9. skip
    skip Enthusiast
    Utah
    1992 std cab, 1986 std cab
    looks sick man! you running 17s?
  10. burnzya
    bodied 73 hilux
    no they're 18's w/ 225/40/zr18, but i need to go down one size
  11. burnzya
    bodied 73 hilux
    re-mounted the beginnings of the core support. i will add more to it once i get the 06 tacoma hood, fenders and grill.
  12. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    06 clip on an 86=BADASS
  13. slacker
    slacker Addict
    84-7m-GTE custom
    I duno .. low is good , but what about a hood ?
  14. burnzya
    bodied 73 hilux
    when i put on the 06 frontend the sheetmetal will be raised to clear the tires. then the hood will fit fine. i was originally thinking 02 tacoma, but then i seen a few with the conversion started. so 06 it is.
  15. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    That is AMAZING work man! You are deff talanted! Im hoping to have the front and rear of my truck on air buy next july. But it sure wont be that low ;)
  16. burnzya
    bodied 73 hilux
    hopefully i won't have to build a truck this low again (unless i'm getting paid to do it) its a pain in the ass. i bought it bagged and planned to do a back half and clean it up. then the parents went thru a divorce and i didn't want my little brother getting screwed up and into the wrong stuff. so i made a deal that if he worked on it, it is his. the ideas started flying and now i'm up to my ears in work. i'm actually starting to feel like stuff is coming together, just need more money to finish it.
  17. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Sry to hear about the rents man. That can be tough times for sure. But on the bright side your building something truly outstanding! And watchingout for your little bro. I bet he is going to excited to roll in that! :cool:
  18. burnzya
    bodied 73 hilux
    yeah he's learning alot, he's 16 and learning how to weld in school, he has already passed flat, horizontal, vertical (up), and overhead with stick and mig. i'm going to teach him how to tig soon. i have to work on a mustang this weekend (replace torn part of floorpan, subframe connectors, rollcage, torque box reinforcements) and if i get it done i'm going to drag my yota in and make it a shortbed.
    this is my yota
  19. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Nice truck to start a project on! Thats for sure. Sounds lke your bro has some talent in the welding field! Specially at 16
  20. burnzya
    bodied 73 hilux
    yeah, must have been my master teaching skills:D :D :D ,
