My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. jetas
    Heres a pic of the booster/MC/proportioning valve. What you cant see is the section if pinch weld behind the booster had to be trimmed to fit this thing in place. And the brake lines are new up front
  2. KS.ID
    KS.ID Member
    Bay Area, CA
    RN22 1972 Hilux
    Awesome! Thanks for that picture Jetas!
    I have the proportioning valve and a 1975 OEM Master Cylinder. I am thinking of rebuilding the Cylinder since its got the "TEq" logo on there.
  3. jetas
    Not a bad idea, shouldnt be hard to do.
  4. jetas
    Been distracted from working on the truck between doing work on the house and helping my fiancée with wedding stuff. Plan is hopefully in January il be replacing seal on the output shaft in the trans, shifter seat/bushing things. And i need to adjust the carb float and check what jets are in it. I have a bit of a fuel smell in the oil.
    Il also be aquiring my dads '95 Silverado early next year which needs some work too. Gonna be fun
  5. jetas
    Well now that the wedding has passed, its time to start getting back to working on the truck.
    Did a compression test a week or so ago and the numbers ranged from 130 to 140 across all 4. Truck was cold, somewhere in the 50° range so im not too sure where these number stand(i know i shouldve warmed it up some) im going to replace the plugs and wires(one had a cut on the insulation and another broke the clip off on the sparkplug)
    Started tackling the rust on the roof and all i have to say is that i shouldve taken care of it a lot sooner. Its coming off but its putting up a fight.
  6. KS.ID
    KS.ID Member
    Bay Area, CA
    RN22 1972 Hilux
    Took me a while to notice, but I also want to upgrade the front end. I just picked up a '76 Grille and valance. I was mocking it up, but noticed the middle support wasnt lining up well. Did you have to modify anything?
  7. jetas
    I pulled that center bracket from a 75+ truck but it still didnt work 100% without some finessing
  8. KS.ID
    KS.ID Member
    Bay Area, CA
    RN22 1972 Hilux
    Okay cool, I got that center bracket too. I'll give it a shot. Thanks
    jetas likes this.
