My 1972 Gen2 build
Discussion in 'Pre-1975 Build-Up/Project Threads' started by jetas, Jan 11, 2016.
  1. jetas
    Theyre buckets i pulled from a 73 Hilux at a JY. Theyre the low back ones with no headrests. They were trashed so I had them refoamed and reupholstered. Vinyl with a diamond stiched tweed center. I fuckin love them
  2. 78lolux
    78lolux Newbie
    Texas
    1978 yota mini
    Straight up! They look classy; really fit the truck. I was checking out the gauges last night from Speedhut and I noticed the 4” combo set they sell with the speedo/tach and the quad cluster; is there any reason you didn’t want to go with dual gauge setup and change both out at one time? Just wondering cause I’ve been kicking around the idea. Thanks
    jetas likes this.
  3. jetas
    Thanks man, i figure il be spending a good amount of time in that truck so might as well have something nice to sit on.
    As far as the gauges go, I already had the Autometer carbon fiber volt and engine temp gauges laying around. I really just needed a speedo. I went with the speedo/tach combo just to clean up the interior a bit since i had the autogage tach sitting on the column(it was annoying me how it looked)
    I may eventually get the quad gauge and eliminate the other 2 if $ allows it some time next year
  4. 78lolux
    78lolux Newbie
    Texas
    1978 yota mini
    Do you happen to have a daytime pic of your headlights? I’m curious to see how they look sitting in the grille.
    Thanks!
  5. jetas
    Got back a few pages on this thread and theres should be a couple pics from July.
  6. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    The gauges look great!
    jetas likes this.
  7. jetas
    Thank you.
    I actually just put some red LEDs in the autometer gauges and the fuel gauge so everything matches the speedo now.
  8. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    I think they're all Photobucket pics that took a dump like everyone's who hosted pics there.
  9. jetas
    Just reposting the same pics. [​IMG]
    Mikerocosms, stacy and 78lolux like this.
  10. Dennis goeden
    Dennis goeden Enthusiast
    warren ohio
    1973 rn22
    any progress ? mine is back on the back burner road crew started salting the roads for snow , so a winter nap for the old girl.
  11. jetas
    Nothing really. Im waiting for the registration papers to come in so i can get it street legal. Still got a lot or small things to do but this damn time change has me all fcked up. 5pm looks like 9pm now.
    Although i am debating on ordering a fuel leve/oil pressure gauge through speedhut right now since theyre having 20% off. Dont think its guna happen
  12. jetas
    Went into the garage last night. Decided to drop to gas tank and try to figure out why the gauge doesnt read anything.
    I disconnected the wire to the sender, grounded it and the gauge moved. So im trying to tweak the sender so itl read the correct ohm range
  13. jetas
    Ok i think i found the damn problem. Soldered in a small piece of thin gauge wire now im actually getting a reading. Tested the sender outside of the tank but hooked up to the wiring and its good. Now i just have to reassemble everything
    90DailyDriven likes this.
  14. jetas
    So far the fix is working. Im getting a reading on the gauge. Is it accurate? No idea lol. We will see when i finally start driving the damn thing
    Eduardo likes this.
  15. jetas
    Well for Xmas my Fiancé ended up getting me a Forever Sharp steering wheel and i finally received the NRG hub the other day so last night i got it all installed. Pretty easy install. Only thing i did have an issue with was the contact for the horn on the back of the wheel is in a different position than what i needed for the hub. Easy fix tho, just had to give it a gentle pull up and done.
    So ive confirmed that NRG short hub SRK-120 does in fact fit the early gen 2 trucks.
  16. jetas
    Big update today. Finally registered and drove the truck today!! I was super excited but extremely nervous at the same time. Put the first 20 miles on her today and she took em like wm like a champ! Heres a short clip after i left the gas station
    Ezy, MTN_Tim, Hands_On_Henry and 4 others like this.
  17. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    He'll yeah!
    Congratulations!
    jetas likes this.
  18. jetas
    Thanks bro. Been a long time coming.
  19. jetas
    Well the first issue came up last night. Drove to a BBQ at a friends house and a small section of hose at the heater core sprung a leak. Wasnt too bad. Figured it out last night and fixed it earlier today. Now i just need to add more coolant for what was lost during the leak and repair.
    Hopefully il get that done tomorrow
  20. jetas
    After fixing that coolant leak everything has been good. Shes taking miles like a champ and we hit 100 today[​IMG]
    ...miles that is...
    KS.ID, shawny2005, Utility 77 and 4 others like this.
