Mechanical temp gauge on 90 22re
Discussion in 'Engine/Drivetrain' started by Jim Thompson, Jun 4, 2023.
  1. Jim Thompson
    Jim Thompson Member
    Hi, me and my son are putting a 22re in his 74 pickup, the engine is out of a 90 pickup, what adapter will I need to install the sending unit in the same place I'm removing the original sending unit? I haven't bought the temp gauge yet, just want to have everything I need before I try and install it ....any help is appreciated
  2. jetas
    You may need a T fitting to fit a second sensor
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Anything that is 3/8" will be Japanese spec but anything 1/2" will be npt. You might have a port you can use.
  4. Jim Thompson
    Jim Thompson Member
    I'm not using the original sender that was electronic , should be able to adapt to that outlet, just not sure what thread it is,
  5. Jim Thompson
    Jim Thompson Member
    Is there an adapter I can get for the Japanese size?
  6. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Depends on the size of the probe. With an adapter you step it down some. So if it's only a little smaller then the threads it will not fit. The British standard will work thought and easy to find.
    Jim Thompson likes this.
  7. fred heath
    fred heath Addict
    Raleigh, NC
    Most early Toyota thread has a 1.25 pitch.
    So either M8x1.25 or M10x1.25. Depending if it’s a nominal 5/16 or 3/8.
    Erwin Merida and Jim Thompson like this.
