Lost fuel pressure
Discussion in 'Engine/Drivetrain' started by Ivey, Jul 19, 2018.
  1. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    When I first got my truck (couple months ago) it would fire up quickly on the first turn. Now I've noticed that it takes a little gas to get it going. When I first bought it the pump was @ 2 PSI and it has since dropped to 1.5 PSI. I'm guessing this the problem (lack of fuel pressure) so I wondering where I should start? Should I replace the fuel filter first?
  2. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Or do I just need to adjust my fuel pressure regulator? I guess I could try that but my question would still be why my fuel pressure is dropping.
  3. jetas
    swap filters first see what that does. Never hurts to have clean filters anyway.
    After that move on to the FPR
    Ivey likes this.
  4. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    I figured I would follow up with my "solution". Turns out the gas cap wasn't twisted on all the way. In Oregon you can't pump your own gas so it took me longer to figure out than it should have. I just go in behind the attendant now and tighten it all the way cause they almost never tighten it down enough.
