It's a pretty tight fit a press is your best bet. Maybe find a shop that can knock it out while you wait.
Aaah shit yes. Definitely need it pressed out. Do you have access to a bench vice? Can try to make that work
They are not that tight that you need a press, you can use a brass drift to knock the carrier off the bearing and it will tap back on again with a hammer
