Engine swap 18rc to 18RG 79 RN41
Discussion in 'Engine/Drivetrain' started by Hilush, Jan 12, 2015.
  1. Hilush
    Hilush Newbie
    Queensland Australia
    1979 RN41 2wd
    All I needed to do was swap the sump from the Hilux 18rc to the GT Celica 18RG (the engine block is exactly the same just the head and internals are different) bolt the engine mounts on and drop it in,Find a straight bit of radiator hose 9 inches long for the top hose the bottom hose is exactly the same, I had to get the Celica extractors modified to fit (they hit the torsion bar in my rhd in lhd the steering column may be an issue) and I also put the internals out of a 22r electronic dizzy into the 18RG dizzy with the coil and ignitior. Instant na 150hp :headbang:
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Can you post a picture of the exhaust side? Where did you get the Celica extractor? TIA
  3. jetas
    If i could find this engine in the states cheap enough id swap it into my truck
  4. Hilush
    Hilush Newbie
    1979 RN41 2wd
    I crashed the other week so the inner guard is off to the left a bit. The extractors came with the engine when I got it.
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    Thanks. So I guess you don't know who made them... :(
    Most extractors are copies of the TRD units that go up and around/over and get too close to the brake master cylinders on USDM cars...
  6. Hilush
    Hilush Newbie
    1979 RN41 2wd
    They are pacemaker extractors.
