Clutch/Rear main tutorial-88 22R 2wd
Discussion in 'Engine/Drivetrain' started by 22R88, Oct 24, 2015.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    Is there a step by step tutorial on replacing a clutch (removal of trans ) on a 84-88 22R engine somewhere online ? In the planning process to pull mine apart over the winter. Looking for tips and lessons learned to make job easier.
    Thanks,
    22R88
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Pull the driveline, put a jack under the trans. Remove everything attached to the trans. Starter, slave cylinder, shifter, speedometer cable etc and the exhaust is either removed or at least loosened up drop the jack. Now you can get to the 2 top bellhousing bolts with about 3' of extension. Those bolts are the toughest part of the job.
    Once all the bolts are removed you can slide the trans back and rotate it and it should drop out with some prying, cussing and frustration. :lol: Everything else is straight forward.
  3. 22R88
    22R88 Veteran
    South Louisiana
    Thanks for the reply. What about loosening the motor mounts ?? Thought I read that somewhere ?? Is that something I should do or don't worry about it ?
    Thanks again,
    22R88
  4. White Trash
    Eastern WA
    There is usually enough give in the mounts but if it fights you just loosening the single stud from the top will suffice.
  5. 22R88
    22R88 Veteran
    South Louisiana
    Thanks a bunch for the advice. it will be of much help when I do the job.
    Appreciate it,
    22R88
