1. jetas
    Hood release is like a bike brake cable
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Totally, I'm actually a part time bike mechanic so I wonder if it is fixable. The retainer end cap on the latch end came off, so pulling the lever in the cab just moves the cable and housing together.
    After dealing with that gas tank I'm ready for something easy!
  3. Justin Danger
    Bay Area Peninsula
    I added a reservoir for windshield washer fluid, "smooth is fast".
    I also went back to my old AFM. I was getting too much air flow and reaching fuel cut on my ECU. I thoroughly cleaned the hoses and painted the parts.
  4. Justin Danger
    Bay Area Peninsula
    Took a 60 mile drive today, things felt pretty good. I drove up to Skyline ridge on the peninsula and cruised along for a while. I was heating up pretty hot on the drive up the hillside, but that was the only heat issue I had the whole drive. Temps were getting close to 212F with both fans on. Nothing boiled over or anything, so it was all fine.
    Driving along Skyline was pretty sweet, lots of beautiful views.
    Not dying on this drive, go away vultures!
    The worst problem I had was while driving on the highway. At speeds over 60mph the whole engine started surging. The ARFs were oscilating, and it felt like I was stomping my foot on and off the gas repeatedly. I only drove 1 exit like that, and got off and drove under 60mph the rest of the drive.
  5. Justin Danger
    Bay Area Peninsula
    Did some interior work.
    The other day I did some "recalibrating" on my boost gauge and ended up busting it, so I decided to reconsider my gauges.
    I ended up ordering a couple digital display gauges for temp and boost that are on their way. Instead of the wood panel to the left of the main cluster, and jenky wooden thing I had on top of my dash for the excess gauges, I decided to integrate them into the dash itself. For this, I sacrificed the center air vents, and installed a hot rod style finned aluminum gauge mount. In place of the gauge that was on the left, I just made an aluminum cover panel.
  6. Justin Danger
    Bay Area Peninsula
    I've had an exhaust tip laying around for a while now, I got it for my new exhaust system but was fond of the round raw pipe sticking out at first. Now I'm reconsidering.
    It is a black double slant for a charger or something. Any thoughts? I could also angle the ends so they are parallel with the body line.
  7. Justin Danger
    Bay Area Peninsula
    Went for another drive today, golly was it hot. 98 degrees at the top of Skyline, but a beautiful drive none the less. I stopped at one point to get a nice view of the bay and some pictures.
    I reinstalled my door panels a couple days ago
    Levi likes this.
  8. Justin Danger
    Bay Area Peninsula
    New digital boos gauge is installed, just need to fit it into the bezel better. One thing that I really likeabout this one is that I can cha ge the color and brightness when i turn the lights on. I chose a turquoise to match my wideband for daylight, andswitch to amber to match the rest of the dash lights when they come on.
    The new temp gauge comes in Monday, same line of gauges, so i can synchronize the color change.
    I'm doing some repair work on my horn button as well. It floats on the spring in the center, and should have three tabs sticking out to hold it in, but one broke, so I will try to use some sculpting epoxy to make a new tab.
  9. Justin Danger
    Bay Area Peninsula
    Loved finding this!
    Oh what a feeling indeed, grrrrrr hahaha.
    I started a new job and have been spending more time driving the truck than working on it. I do plan to work on the rear suspension today. I've got a couple 1" block to install in the rear to level things out. I am worried that the shocks that I am running are too soft and that my axle will get a little to intimate with the frame, so I might put the coiled shocks back on only in the rear.
    I also finished fitting the gauges in the dash, and they look so nice! I'll try to get a pic of that up too.
  10. Justin Danger
    Bay Area Peninsula
    So here are the gauges all cleaned up. The temp is in Celsius, but thats alright. ( a lavender plant grows in my yard right outside the passenger's side door, so I usually get to have a natural air freshener going on!)
    These gauges come with an alarm I can set for certain points, so I set the boost gauge to beep at 10psi, and I set the temp gauge to beep at 100*. I have my e-fans on a manual switch, and sometimes don't pay the best atgention, so I figure 100* will let me know when I've slacked off on turning the fans on.
    I also made a little plaque for the grille, had no idea how much of a difference it would make.
    I finished the rear suspension work earlier, and was so disappointed in the rear shocks when I removed them. I was comparing compressed lengths of them to my Monroes by clamping down on them with a ratchet strap. The compressed length was just what I expected, but when I took the strap off, they expanded halfway, then froze. I don't want my shocks freezing halfway through travel!
    I reinstalled the Monroes that have a coil built in and figured that would help prevent bottoming out on my frame and get rid of those POS Gabriels. The spring assisted shocks plus 1" drop blocks ended up in losing only about half on inch of height in the back. Half an inch isn't much, but it definitely looks better. Time will tell how it handles.
    yotarip likes this.
  11. Justin Danger
    Bay Area Peninsula
    Took the scenic route through the mountains after work today to grab a couple cold brews and a good burger at the ol' new Alpine Inn.
    jetas likes this.
  12. Justin Danger
    Bay Area Peninsula
    Relocated my gauges. They were hard to see in sunlight on the dash, so i got a pillar cluster.
  13. jetas
    Pillar pod looks good
  14. Justin Danger
    Bay Area Peninsula
    Thanks! It is alright. The bottom gauge faces me, but the upper 2 are facing someone who has their head through the roof. Luckily the LED gauges i have are super visible. Also wish it had factory mount points, I always hate having to drill holes in my truck!
    Up next is a 'new' remanned steering box. The used manual box I've been using for years is super sloppy and always has been. I'll be installing that and a new steering wheel in the next couple weeks.
  15. Justin Danger
    Bay Area Peninsula
    I've been DFing the truck for a few months, and am getting around to fixing a few bugs in the system. The first and moat annoying was the steering gearbox.
    When I switched feom power to manual steering, I just got a used box to put in. It had a little slop, and that has only gotten worse and worse over time. I found a remanned unit online, and bought it. While waiting for it to arrive I realized that a new 4wd pitman arm is very easy to find, but one for a 2wd is impossible. I then proceeded to break every puller I had before dishing out the 15$ for a dedicated pitman arm puller. After that, everything went smoothly. I took a short jaunt, and steering feels so nice and tight.
    Next on the list was my EGR valve. When I was having issues a while back, I blocked off the valve where it enters the upper plenum. Since things have been running nicely, I decided to take out my blocker. Driving around town was fine, but at highway speeds the engine presented with it's occasional buck again. I guess I now know what the problem is, and either need to try cleaning that thing or replacing it. I would like it functional again considering my MPGs have dropped a bit since blocking it off.
    Last "bug" was my igniton. I've been running the stock system for a while, and things have been fine, but I wanted to try reinstalling the FAST system that I got from LCE. I was able to scrounge up my old wiring diagrams and got it hooked up. I then set idle and timing. The timing seemed to be jumping around a bit, which i found odd, but I set it best I could. While test driving I noticed a stumble when starting from a stop. Acceleration was responsive after the stumble, but the stumble was from every single stop, and quite annoying. I checked idle, timing, and all of the wiring, and drove for a few days. I couldn't get things to run right, so I just went back to stock, and will probably never install that FAST system again.
    Lost somewhere in the san francisco usps distribution center is a new steering wheel adapter and new steering wheel I ordered. With the new gauge pillar I decided to get something a little more sporty. Updates to come...
  16. Justin Danger
    Bay Area Peninsula
    Sporty feel
  17. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Luckily usps is good with reimbursement if its truly lost. I've had stuff that a seller poorly packaged that must of fell out at sorting and I had no problem getting my money back.
  18. Justin Danger
    Bay Area Peninsula
    Shipping info now shows that the wheel has successfully reached Guam.
  19. Justin Danger
    Bay Area Peninsula
    Took an evening cruise up twisty hill roads the other evening that was driven to the soundtrack of squealing tires and turbo whistles... gosh I need a seat with better bolstering! haha
    Turns out that my radiator had a leak in it. I ended up losing so much coolant that the system overheated and blew a coolant pipe off. Luckily since I transitioned to copper pipes that just means sticking it back in the hose and clamping it up again.
    The radiator is 3 1/2 years old, which is longer than I expected the thing to last (cheap aluminum), so now I'm in search for a new one. I've found a 4 core mustang radiator that fits the dimensions that I'm looking for, and it comes with a 3 year warranty, so I might hop at that.
    My steering wheel (that came from Phoenix, AZ) has made it out of Guam, and is now in Hawaii. Maybe some day after it's vacation I might get to put it on my truck.
  20. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    :ROFL::ROFL::ROFL::ROFL:
