75-78 20R throttle
Discussion in 'Engine/Drivetrain' started by jetas, Apr 29, 2015.
  1. jetas
    Anyone have a good pic of the factory throttle linkage or cable from the pedal (engine bay side) to the carb? My truck had a 20R swapped in at some point but throttle was never hooked up
  2. tyrap26
    tyrap26 Enthusiast
    Thats the best I found ... Everything has been pulled out of the bay for a few weeks now.
    sorry
    1976 SR5 likes this.
  3. jetas
    Thank you for that. I think i have most of the parts for it. But im half tempted to do away with the linkage and just run a cable setup new pedal assembly and all
  4. tyrap26
    tyrap26 Enthusiast
    My stock one worked perfect for me.. I'd try and hunt for a stock setup instead of ditching it.
  5. jetas
    I think i might have to just set it up right. Cuz the linkage was just mounted (poorly) to the firewall
  6. tyrap26
    tyrap26 Enthusiast
    should be 2 bolts holding the 'pivot' which the rod hooks up to on the firewall.
  7. jetas
    I might have to go scrounging thru the junkyard and hope i find something
  8. 1976 SR5
    1976 SR5 Member
    Sacramento, CA
    1976 SR5 long bed
    How did this work out? The carbs and the header on what looks to be a well used 20R? I am thinking about doing something similar.
  9. Henry
    Henry Enthusiast
    Washington State
    OP, did you still need a photo?
  10. jetas
    Na, i ended up switching to a throttle cable
  11. Henry
    Henry Enthusiast
    Washington State
    How difficult was it to setup something like that?
  12. jetas
    Wasnt too bad. Lokar universal throttle cable, weber throttle cable kit, and i fabbed a custom gas pedal using the factory firewall mount. Was pretty straight up just took some tweaking to get it right.
  13. Henry
    Henry Enthusiast
    Washington State
    Any photos? Sounds like a great upgrade.
