4Runner Center Console
Discussion in 'Interior/Electronics' started by mprtftr, Mar 29, 2012.
  1. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    For those that said they didn't use the heater as the bracket, did you have to modify the console to install it? I'm trying to do this and the opening isn't lining up around the stick-shift.
  2. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    37 views and no help??? Come on guys, someone has had to deal with this. HEEELLLLPPPPP!!!!!!!
  3. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I have one in mine an I just cut out a little more for the shifter
  4. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    Yota, do you have any pics of your install? And how did you mount it to the floor? Did you use the heater?
  5. biketrials25
    biketrials25 Member
    Charlotte, NC
    1980 Hilux
    I just mounted mine with a bracket I made. I had to install rivnuts to mount the back section and weld a tab to my shift plate to mount the front section. It turned out pretty good and is very solid.
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Mines just sitting in there still but I have all the front mounts from the 4runner its just a temp thing until I body it an build a fiberglass center console
