So I damaged the rear section at the roll pan, drove off the ramps without seeing the rear was down. So repair work is in motion before another show year. So after welding the corner back up nice & strong I cut a piece of 1'x1' & welded caps & both ends than drilled 4 holes & plug welded the piece behind the lower part of the roll pan to give more strength. I will seam seal the piece completly in from the rear Next start the body work & than repaint
Got the first coat of short strand Kitty Hair on & sanded out, & placed strings across area to check for straightest
Getting the work done, got all the charcoal paint work done,base coats, clear with red pearl in it, & than 7 coats of 2k chip guard. Today I'll mask off the bottom & do the red touch up work,have 3 weeks to get back together before the first show for 2022.
