1982 GT Hot Rod Mods
Discussion in '1976-1983 Build-Up/Project Threads' started by mike1305, Jul 6, 2020.
  1. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Guess it makes more sense to put my future work in a build thread vs. an intro thread!
    My little 82 is getting a nice mechanical refresh. We're not in Kansas... er... California anymore...
    This just arrived in the mail today...
    Parts list (what have I got myself into...)
    LCE Street Header Kit 2WD Direct Fit 22R/RE 1982-1984
    - Street Header Gasket Set - 20R/22R/RE (1975-1984)
    - LC Engineering 22R/RE Header Connector Pipe 2WD 1981-1995
    - Universal 2-Bolt Stub Connector Ceramic Coated
    - Street Header Only (2114) - 20R/22R/RE (2wd)
    - 2 1/4" Exhaust Clamp
    - Header Stud Set - 20R/22R/22RE/2RZ/3RZ
    Weber 32/36 Carb & Intake Performance Package 22R with Stock Weber Air Cleaner
    - Offy Manifold To Weber 32/36 or 38 Carb Spacer
    - 22R/RE & 3VZ Thermostat Housing Gasket Round Rubber
    - Offenhauser Performance Downdraft Intake Manifold 22R 2-Barrel Weber Carb. Flange / Single Plane
    - Weber 32/36 Carburetor Kit With Electric Choke - 20R/22R
    - Offenhauser Performance Manifold 22R Install Kit (Single Plane)
    - Water Block Plate(Center Of Head) - 20R/22R
    - Water Block Plate-20R/22R/RE/RET(T.C. Pass. Side)
    - Water Block Plate Kit(8 Bolt) - 22R(Under Intake)
    - Intake Manifold Gasket Set - 22R/RE/RET
    - Intake Manifold Plug Kit - 22R(Carbureted)
    - 20R/22R Thermostat Housing Adapter Kit For Late style Water Neck
    Heat Riser Kit - 20R/22R
    - Heat Riser - 1.5" x 36" Heat Riser Tubing
    - Heat Riser - Clamp On Header Standoff (1.5" Tube)
    - Hose Clamp - #20 (13/16" to 1 3/4") Box of 10
    Air Injection Adapter Kit - 22R/RE(81-84)
    EGR Block Plate Kit - 20R/22R(Carb. Only)
    Street Tune-up Kit With Plug Wires 20R/22R/RE (1980-92)
    - Street Distributor Cap 22R/RE 1981-1992
    - Pro Distributor Rotor - 20R/22R/RE/RET(80-95)
    - NGK 7mm Spark Plug Wire Set 20R/22R/RE/RET 1978-1992
    - Spark Plug NGK BKR5EYA
    Plug Wire Separator Kit For Pro Wires (8.5mm) - Blue
    H4 Headlight Conversion Kit 1982-1995 Pickup & 1984-1991 4Runner
    Holley Fuel Pressure Regulator Gauge Kit (Carb. Only)
    - Holley Fuel Pressure Regulator (1-4lbs)
    - Fuel Pressure Gauge"T"Fitting 5/16"Hose to 1/8"npt
    - 1/8 Hex Socket Pipe Plug - Dryseal 3/4 Taper
    - Fuel Pressure Gauge Low pressure For Carbureted 0-10psi 1.5"Dia.
    2 1/4" Pro Flow Turbo Muffler (14") - Satin
    Peter T likes this.
  2. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    I don't have much free time in the next week, but I'll probably start with the headlight kit first since I need to get the grill sorted anyway. The 4WD grill doesn't fit as well as I hoped and I gotta figure out what McGyvering I need to do, so that whole front fascia will get fixed at once. Then probably the headers/muffler, then intake stuff later. I'll try to take some before/after photos and videos of the look and sound as we go along. Wish me luck.
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Looks like some fun to be had, nice not being in california, eh? good luck
  4. jetas
    Screw it man even in Cali all it takes is a few hundred bucks and your truck is "smogged"
  5. Justin Danger
    Bay Area Peninsula
    I've been pulled over by CHP that told me to pop my hood, kicked my tires, and said "what else can we find wrong".
    Not sayin ACAB, but it only takes one.
    mike1305 and jetas like this.
  6. jetas
    Luckily ive never had that experience. And i have to agree they aint all bad.
  7. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Well a friend and I had a few beers and decided to get to work Saturday. Got the old exhaust off, albeit with some curiosity. Some mismatched studs that came out almost by hand were certainly strange. After that we called it an afternoon. Yesterday I realized I might have mis-ordered some parts from LCE, but regardless I decided to go full desmog instead of the halfway plan I had before. so I started ripping out anything with a vacuum line. Started getting sketchy about stuff that smelled like fuel because I don't know what I'm doing so also left it as you see for the night, lol.
    This is my third vehicle so I guess there isn't much of a sense of urgency yet.
    Cheers
    Erwin Merida likes this.
  8. jetas
    Theres still a lot more shit you can pull off for the desmog. Engine will look pretty bare when its done
    mike1305 likes this.
  9. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Just from personal experience, mismatched studs probably means the truck's PO lost some studs due to vibration. I lost a few nuts AND studs (I think they came out as a unit, together) due to vibration when I messed around with a header for my 20R in my Celica. I ended up replacing them with bolts but it's better to use studs in aluminum.
    Be careful when installing your new header to torque down the nuts and watch them for a few hundred miles to make sure they stay put. I even used high temp RTV to lock the exhaust manifold nuts.
  10. Toyaholic
    Toyaholic Newbie
    Vancouver, WA
    1977 Hilux Chinook
    Im looking at headlight conversions...wondering how you like the Rampage??
  11. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Welp, many months and beers later, humpty dumpty is back together again. after a trip to the mechanic to tune the carb and ensure I hadn't created a fire hazard (lol) it's running as good as new. Aside from earlier today when the throttle linkage disconnected from the throttle and the engine tried to redline itself to death in traffic. Story for another day, nothing that a roadside ziptie didn't take care of. Next up is general engine bay tidiness, dealing with all the excess wiring created from removing 10,000 sensors, a pressure wash, maybe a matching valve cover... and finding the proper plastic clippy bits to affix the grill so I don't have to use more zipties, haha.
    Any suggestions on the interior? Wondering if I should leave it all blue to match the engine bay, or add some more black accents. That passenger door card should be really fun to take off, given that my grandfather had drilled in the window crank at some point. I assume any and all parts outside the engine bay are unobtanium. ugh
  12. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Nothing like replying a full year later... but I haven't done any night driving yet. Not even sure if they are aligned properly tbh. Will report back once I actually know, haha.
  13. MrDinkleman
    MrDinkleman Addict
    SoCal
    It's hard to tell but if those are K&N type cotton gauze filters (air and breather), they should be oiled. Spray each pleat with K&N filter oil.
    Nice job.
  14. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Not sure actually, it's what came in the Weber Carb Kit. I'll take a look, and thanks for the tip!!!
  15. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    All tucked away in our new home! So much room for activities. Photobombed by the Grand Sport too haha
  16. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Hoping to have this look in the next month or so. Roll bar will be tough and expensive to source or build, but decided to just keep the wheels I already got and throw some 225 T/As on it. Here's to hoping the torsion bars won't give me nightmares like half the other folks here, and will have to play around with block kits and new shocks for the rear once the new tires are fitted. Still on the fence about plasti-dipping the wheels, but I guess if I hate it, I can just peel it off. and if I love it, can do something more permanent. Or not. This isn't a show car!
    Peter T likes this.
  17. mike1305
    mike1305 Newbie
    Colorado Springs
    82 SR5 2WD 5MT
    Engine bay tidied up with a billet loom and some new wiring. About halfway there. Still need to replace connectors for the terminals and the driver side of the engine, all the ignition stuff.
  18. Sk1dmark
    Sk1dmark Enthusiast
    New Jersey, USA
    1977 Toyota Pickup, (SOLD) 1974 Hilux
    This thing looks great! What wheels are those? Stock for an 82?
