1980 pickup w58 swap
Discussion in 'Engine/Drivetrain' started by Hayden, Dec 7, 2017.
  1. Hayden
    Hayden Newbie
    I have a 20r with a 4 speed i want to do a 5speed swap but the only 5 speeds i can seem find are w58s. Does anyone know if it could be done?
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Hayden likes this.
  3. jetas
    W58 is a desriable one because of 5th gear. If you can get it cheap do it
  4. fred heath
    fred heath Addict
    Raleigh, NC
    Both are 5 speed transmissions. Why is the W58 better? Especially if the G54 is almost a perfect swap.
  5. Hayden
    Hayden Newbie
    I can pick it up for $200 . It has some miles on it but i don’t think that 20r can hurt it any. I just want a fairly easy swap.
  6. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Make sure you have a bellhousing that's correct for a 20r/22r to W58 transmission. The older 20r bellhousing is NOT a compatible match. The 5 speed transmissions that were originally offered was the w50, which has a different bell than the later w55/w56/w57/w58/w59 transmissions took
    I have an extra if you're anywhere near Houston, TX.
  7. Hayden
    Hayden Newbie
    I’m in Springfield Mo. I can’t find any parts around here. I’m wanting to Ls swap it Eventually I’m thinking the w58 would hold up.
  8. Tuhd The Troll
    Houston, TX
    1982 SR5
    The w58 will hold up to a small LS swap if you're not launching it at the strip, but if you want to put any amount of power adders on it or drive like a jackass (like I would), you're going to be looking at upgrading more of your drivetrain. It may be worth your time and money to send the transmission off to Marlin Crawler for a heavy duty upgrade to the internals when you LS swap it, so it can take the added power
  9. Hayden
    Hayden Newbie
    Yeah i already figured l would need to beef my rear end up for sure. But i wasn’t sure on the w58 what it would hold up to.
