1976 Toyota Pickup AKA Blue Magoo
Discussion in '1976-1983 Build-Up/Project Threads' started by Ivey, Jan 14, 2020.
  1. SteveWippins
    SteveWippins Enthusiast
    1988 base model
    Really hoping we get some more updates on this thing. Absolutely awesome truck. And like others have said, that blue is SO good looking.
  2. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Ask and ye shall receive.
    I still need to fix some dents and work out my electrical gremlins. I need to do new bushings on everything and try to find a LCA for a decent price, that will probably be my summer project. The next big project is to cut out the floor pans and replace them. I have the pans and even a welder I just haven't had the chance to really mess around with it. Once thats done carpet, new seats and fix up the dash. Lastly I have to rebuild the motor at some point. I'm getting a bit of chain slap but it can probably go for a while.
    Erwin Merida likes this.
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    SteveWippins likes this.
  4. SteveWippins
    1988 base model
    I've actually got the same tachometer "mounted" to my steering column with zip ties lmao
    Ivey likes this.
  5. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Yo, that's a unique upgrade! Tach on the fender mirror!! :eyecrazy: that's radical!! Love it
    Ivey likes this.
  6. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Thanks! The glass fell out of the mirror and rather than buy another set I decided to stick a tach in there. Works pretty well and its lit up at night.
  7. SteveWippins
    1988 base model
    My girlfriend says she loves the exhaust tip lol
    Ivey likes this.
  8. nottoshabi
    nottoshabi Enthusiast
    What is the rev max on these engines? I need to get a tach as well I don't know how high they rev to.
  9. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    It doesn't really go over 4k rpm for me but I also have a weird ratio in my rear dif and its a 4-speed.
  10. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Stock 5500 rpm. You might not feel much power at that range. A little head work and cam can change that. It's been a it's been awhile since I've calculated theoretically rev limit. Most cast pistons can't go much over 6k before you run into major problems with such a long stroke. Also heard the crank pulley likes to fall apart after 5500.
    nottoshabi and Erwin Merida like this.
  11. Erwin Merida
    Mines goes to 6k (22re) but falls flat after 5k. I thinks we're used to the torque down low. A tach is a good way to keep things under control on 30/40 yr old gear.
    SteveWippins and nottoshabi like this.
  12. SteveWippins
    1988 base model
    22R carbureted, I typically shift around 2500 or a little lower and normally won't go over 3k
  13. Erwin Merida
    Sounds very responsible.. I wish I could say the same about my habbits...hahahah.
  14. Erwin Merida
    By the way, you can easily get a tach for ~$30 with a mount. Red wire, black wire yellow/green signal wires.. super easy on these engines . Signal wires goes to the positive side of the coil and you have a tach!!
  15. nottoshabi
    Im looking to get one that would fit in the place of the speedometer. I don't want to purchase one that goes to 13 when the truck wont pass 7. Ideally I would like to find one where the redline would start at 5 or 6. Can they be special ordered?
  16. Erwin Merida
    You can but I'd imagine a custom gauge to be pricey.. have you checked out @jetas truck?! I believe he uses speedhut gauges in place of the OEM.. there also a few more member that have done what your tryna do hopefully they chime in with some knowledge.
    nottoshabi and Perkolator like this.
