Hello, I have a 1975, 20R, truck. The wiring harness is fried. I will be rewiring the whole truck. I am looking to swap my points ignition system with an electronic system from a 78. I was told the 1975 distributor was a one year thing, and only a 1975 distributor will bolt to a 1975 head. I hope this is not the case............Thoughts?
I've never heard that the 1975 distributor is unique nor have I ever worked on one but I believe you can just swap the guts. I swapped the guts from a 1979 electronic distributor into a unknown year 18RG distributor. I wanted the correct pick up, reluctor, and connector to plug into my ignition wiring in my 1979 Celica. From what I could see, everything about the guts were identical/interchangeable except for the advance weights which i assume were different to create a different advance curve.
Thanks for the reply. I just bought an electronic distributor for 35.00, I was going to risk it. The ad said 75+ distributor. You confirmed my thoughts, Thanks
Don’t forget you’ll need a coil with ignitor to use with that factory electronic distributor. A new ignitor can run $250.00 if you can find one. You might want to consider a complete aftermarket ignition system. If you have deep pockets, DUI corporation makes a high end HEI setup.
The distributor I ordered looks like it has 2 vacuum canister/ lines. Why 2? Do I need to hook both up to vacuum, or plug one?
The "new" distributor bolted up nicely. Working on making a new wiring harness for the entire truck now. Shouldn't be too bad, I like wiring.
I'm about 80% done with the wring harness, but the distributor I ordered was listed as a 1975+. The distributor bolted up perfectly, and I ordered a 79 cap and rotor. The 79 cap and rotor were too small. It uses the bolt on cap, which is what I ordered. There are no numbers on the distributor, but it bolts to my 1975 motor. Going from points to electronic. What part number do I need for the cap and rotor?
The larger distributor cap I needed is Advance Auto part number CAC1318. Rotor button DAA1151. Pick up coil MEA2318. Plugs Autolight 64.
