hey i did some research about it and found out that there WAS a read disc conversion kit (bolt on) that was made but the place is out of business now... but time to replace my brakes and was hopping if anyone knew of a place i can buy a whole bolt on kit for the upgrade instead of peicing it all together... of if there is a write up on this... i remember seeing one recently i will continue looking... thanks!
google does wonders these days this is just one http://www.allprooffroad.com/pickupbrakeupgrades/255 and a home made "kit" http://yotatech.com/f116/rear-disc-brake-conversion-writeup-121582/
wow thanks man... i tried google enough lol hahah couldnt find that site at all... wow $500 us huh thats pricey... but may be well worth it.. thanks alot man much appreciated........
Both of the sites are for 4wd trucks,6 lugs! Also use a GM rotor so if you use another the offset @ the brackets will not center the caliper over the rotor! 2wd drive trucks ,the Mustang SVO rotors are 5 lug,same bolt pattern & same center hole ID,( had to make my own bracket)!
