year interchange from 81 to 92 22r to 22re
Discussion in 'Engine/Drivetrain' started by warbird, Apr 29, 2014.
  1. warbird
    warbird Member
    so i am looking at buying a 92 reguler cab with 5spd and 22re. as a daily to get me back and forth for better gas mileage than my suburban.... i'm also gonna drop it and make it handle better. just cause. my question is. i also have a 81 longbed with 5spd and 22r setting in my buddies field with a rusted in half frame and horribly beat cab.... are any of the mechanicals between the two interchaengable?
    as in could i rebuild the 22r long block from the 81 and have it as a spare for the 92? how about the tranny? rear end?.... is anything swapable between the 2?
    thanks in advance
  2. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    Toyota changed the 22R in September 1984. The 85-95 22Rs are all the same, everything interchanges. The pre 85 blocks have a taller deck height, use different pistons, different cylinder head, different water pump, different timing chain cover. The pre 85 blocks are also not tapped/threaded for a knock sensor, since EFI was first available for trucks in 1985. The oil pan, connecting rods, rear main seal housing, are interchangeable. That's about it.
    5 speeds did not come in Toyota trucks until 1983. It is probably a G series 4 speed. All 22R blocks have the same bellhousing bolt pattern, whether pre 85 or post 85
    Rear axle, differential, etc all interchangeable.
  3. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Toyota pickups had available options of the w50 5-speed transmissions as far back as '76. Pre-83 blocks also have the double row timing chain (may have been a few 83s with double row as well), so that's one extra point of reliability.
    Pre-85 blocks also will accept a 20r head if you want a tad more compression and smoother airflow through the head.
    Expect to have your driveshaft length adjusted.
  4. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    Ah, yes, thank you Tuhd. I was thinking of 5 speeds in 4WD trucks. I believe 83 was the first year for that.
