Window regulator
Discussion in 'Interior/Electronics' started by Ivey, Feb 23, 2019.
  1. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Anyone know which one fits our trucks? I wasn't able to find one on Rockauto and I'm seeing a couple different models online.
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    I see many for sale too, all look like the same units for an RN20 Hilux, I’d assume they all fit since they specify our trucks
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    So I bought the one you see all over the place and it does NOT fit. The bolt holes are off. Anyone got a line on one? There is a junkyard about 2 hours away that has one for $75 but that seems steep and the drive is a PITA.
  4. jetas
    Can you make it work by drilling new holes?
  5. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Maybe but they would be really close to the existing holes so I'd be worried about the strength of the metal. I just went ahead and bought one off the junk yard guy.
  6. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Got my junk yard window regulator installed and I'm back in business. The regulator for the RN20 is different enough from the RN30 Toyota regulator that you are going to have problems. The bolt holes are off and the rail that attaches to the window is longer on the RN20 regulator. You would need to use the glass mount from a RN30 or weld new tabs on the old mount.
