wheels fitment clearance
Discussion in 'Wheels/Tires' started by alva91, Mar 1, 2016.
  1. alva91
    alva91 Newbie
    shafter,ca
    1994 Toyota pickup 2wd
    i bought some wheels for my truck and when i install them the wheels were hitting the upper control arm.
    How can i correct this and the wheels are 15x8 on 185/50/15.
  2. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    You need some wheel spacers.
  3. alva91
    alva91 Newbie
    shafter,ca
    ok thanks, what size should i get for the wheels spacers.
  4. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    However much you need to clear safely
    90DailyDriven likes this.
  5. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    What's the backspace of the wheels?
  6. alva91
    alva91 Newbie
    shafter,ca
    im not sure whats the backspace the person that i bought them just said it was 15x8 with 25 offset.
  7. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    Wrong offset. That offset would work if the wheel was 17". Not sure if 16 will clear either. You could get spacer, but the last time I got spacer I didn't have enough thread to screw the lug nut on.
    Danica likes this.
  8. Perkolator
    Placer County
    1975 Hilux
    25 offset, yeah that's like a 1" offset or 5" backspace. 0 offset would be a 4" backspace for your 8" wide wheel.
    Wheel spacers or get new wheels is your only option really. If you go with shallow spacer inserts you may require longer wheel studs to have enough threads. Wheel spacers with their own lugs are safer obviously but they are thicker and start sizing over 1" thick I think
  9. jetas
    Get bolt on spacers and make sure you torque them
  10. alva91
    alva91 Newbie
    shafter,ca
    ok thanks @Perkolator i order some 10mm wheels spacers and extended wheel stud. lets see if that will work.
  11. redman
    redman Enthusiast
    Southcentral PA.
    Actually a 8" rim with 0 offset has a backspace of 4.5". Rim width is measured where the bead of the tire seats and is not the total width of the rim. Need to add roughly 1" for the total width of the rim. So 8" rim + 1" = 9" with 0 offset is 4.5" backspace.
  12. disturbio
    disturbio Enthusiast
    Yuma AZ
    1972 Yota HiLux
    Anybody know where to get a longer wheel stud. I tried Napa and copper state bolt. No luck
  13. Tuhd The Troll
    Houston, TX
    1982 SR5
    Ebay and Jegs are probable places. Summitracing possibly. The thread is 12mm x 1.5, and stock are a little over 1.5 inches (40mm), so however much longer you need, add to that. One extra inch would be 65mm long, or about 2.57 inches.
