wheel spacers for 91 toyo pickup
Discussion in 'Wheels/Tires' started by NickAyala25, Jul 29, 2018.
  1. NickAyala25
    NickAyala25 Newbie
    Guam
    1991 Toyota pickup single cab
    Hey guys, when I turn all the way in either direction my tires rub on a bolt on the control arm. What size wheel spacers should I use?
  2. Clay
    Clay Member
    Ohio
    93 Pickup
    The thickness of the spacer depends on how much you are rubbing. You'll likely need longer studs as well.
  3. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Put 4wd fenders/flares on it and do 3" spacers :p
  4. jetas
    What bolt?
  5. Avery Rucker
    Avery Rucker Member
    South Carolina
    92 Toyota pickup base
    I had a similar issue, some people say go wide some people say be conservative. I'm in the camp that says get a spacer that gives you just enough clearance to remove all rubbing/touching in your setup. I literally have ran spacers that were like 3mm to clear my brakes. I had just enough room to slip a note card between the two but since then I've had zero rubbing.
  6. jjmartinez1987
    jjmartinez1987 Member
    Glendale, AZ
    1995 Pickup
