What weight/brand motor oil are you using?
Discussion in 'Maintenance/Repair' started by Spacemonkee23, Oct 29, 2013.
  1. Spacemonkee23
    Spacemonkee23 Newbie
    As the title says...
    What weight/brand of motor oil are you using. I have over 300,xxx miles on my 77 and it burns oil and coolant like no other... I am currently using 20W-50, should I be using 10W-30 and some Lucas stabilizer instead, Cold starts (mornings are only around 50F degrees outside) are a bitch to get running... Miles plus too thick oil maybe my culprit?
    What is everyone running?
  2. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I'm running 10w-30 in my '77. I don't care what brand as long as it's not the cheap stuff. I have almost 200,000 miles and don't burn much if any.
    David Eidson likes this.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I usually run Castrol or penzoil. Fram filters usually. 10-30 oil. Old motors I run 20-50. It keeps the pressure up and doesn't seep past bad valve guides and piston rings as easily.
  4. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Castrol GTX in all my cars except for my IS300 which I recently switched over to Mobil1 because I only change the oil twice a year.
    I use manufacturer's recommended viscosity: 20W-50 in my old cars and 5W-30 in the newer ones.
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run Castrol GT 20-50 in all my rides!!:cool:
  6. 78_LongBed
    78_LongBed Newbie
    Virginia Beach, VA
    78 SR5 Long Bed
    dont really know why people run 20-50 in these motors as small as some of the oil passages are. my guess for the cold start issue is a stretched timing chain, and the tensioner is having a hard time taking out slack when the oil is cold. I run Valvoline MaxLife 10W-40 with a motorcraft oil filter in everything.
  7. night_amuse
    night_amuse Member
    Edmonton, Alberta
    81 4x4 4spd
    any of my stuff that burns oil i usually run 10w-30 in the summer with 1 litre of 20w-50 mixed in. my Silverado burns oil kinda bad and adding a litre slows it down alot
  8. Litneon
    Cocoa, FL
    94 xtra cab
    I've been running 10-30 full synthetic for the last 7 years or so. Runs just fine, and I don't have to worry about going over on mileage between changes. I don't have a preferred brand, just whatever is on sale that week.
  9. first80toyota
    Pacific Northwest
    '77 Hilux
    I'll update my answer, since I changed motors I now only run Brad Penn 5w30 and toyota oil filters
  10. 78_LongBed
    78_LongBed Newbie
    Virginia Beach, VA
    78 SR5 Long Bed
    I noticed a huge change from just super tech or whatever's on sale 10w-40 to valvoline max life. My 87 went from burning a quart every 800 to a quart every 2500 or so
  11. msane99
    msane99 Member
    full synthetic 5w30 Valvoline and big Toyota filter in both my 22re and my 20r.
  12. Broke
    Broke Newbie
    Straight 30w HD is all I've ever ran in everything from old worn American v8s to magnesium air-cooled VWs. ****s cheap and seems to do the job.
  13. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Amsoil 0W-30 with large WIX filter
  14. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Anything but pennzoil in either 10/40 or 15/40 if I'm changing it at work since we have barrels of delo 400 and a big WIX filter never, EVER a fram, they are absolute shiat.
  15. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Apologies for the necromancing of this old thread, but I am curious as to what oil and filter would be appropriate to run for future reference (will have to re-check the manual for the specifications tomorrow.) Tomorrow I will be doing an oil change since it looks pretty black; The oil and filter I will be using is STP High Mileage SAE 5W-30 with a 90915-YZZG2 filter.
  16. jetas
    Purolator filters on everything. May be switching to WIX pretty soon just because of local availability. And i want to say im running 10-40
  17. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    I use toyota filters, and 10w30 conventional
  18. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    Did the oil change with my specified oil, the previous oil was as black as night!!! Much more relieved I did it now :waytogo: Doing it was so easy on this truck its amazing! Aside the sideways filter and me spilling about half the oil I put into the filter, it went smoothly!
    Toyotashack likes this.
  19. Toyotashack
    Toyotashack Enthusiast
    Monroe, WA
    77 hilux 92 2wd 89&90 runners
    ☝️ Toyota filters. Valvoline vr1.
    There is oil filter relocation kits out there.
    Erwin Merida likes this.
  20. fred heath
    fred heath Addict
    Raleigh, NC
    Mobil 1 in everything. 15-50 oil, 75-85 in trans and 75-140 in rear axle. Fram for filter. I log extreme mileage(600 miles in 1 day) on many cross country road trips. Found engine and drivetrain ran much better with synthetic lube. You don’t get the viscosity breakdown like you do with Dino oil. The cost difference between the two is minor.
