what trans do I have
Discussion in 'Engine/Drivetrain' started by bluejean, May 13, 2015.
  1. bluejean
    bluejean Newbie
    New Jerasey
    1994 toyota pu 2wd
    I have a base model 1994 toy pu 2wd 2.4 eng. 5 sp. manual trans. What type of trans do I have r150, w56, w55 ? Is there a tag with it labeled? Also what type of gear oil should I use?
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Odds are it's a w55 use gl4 rated oil.
  3. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Open the drivers door and look for the tag with tire pressure, barcode, VIN and other info on it. Below the bar code will be a list of codes broken out by slashes like this: C/TR A/TM A01 ect. The trans code will be in there.
  4. bluejean
    bluejean Newbie
    New Jerasey
    1994 toyota pu 2wd
    gl4 what weight oil?
  5. White Trash
    Eastern WA
    85/90 is fine. I run redline mt90 synthetic.
  6. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Toyota spec for the W55 is 2.7 quarts of 75W90 or 80W90 depending on climate.
  7. bluejean
    bluejean Newbie
    New Jerasey
    1994 toyota pu 2wd
    The synthetic oil reads gl5 on it or should i stick with gl4? And the climate of New Jersey.
  8. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Has anyone tried Motorcraft gear oil in their W50 or W55?
    It gets a lot of good reviews on the Miata forum.
  9. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    GL4 only. GL5 made my trans real notchy and rough to shift.
    The redline MT90 that WT suggested is great stuff. I have it in my trans now and it really improved the shifting smoothness.
  10. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    GL-5 does not directly supersede GL-4, and the GL-5 is notoriously hard on synchros.
