What pump
Discussion in 'Engine/Drivetrain' started by wuedo347, Sep 20, 2010.
  1. wuedo347
    wuedo347 Newbie
    dfw
    85 yota xcab
    What fuel pump should I use on my 85 22r with a weber 32/36?
  2. toyota21
    toyota21 Member
    the stock mechanical should be fine. if you go electric you could find some cheap ones. just dont buy those little rattle boxes, they dont last long and will have no fuel on wot. the rotary ones are best
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    the lil cheapo mr. gasget 42s or a knock off of it is a good one. its what im running. I did have it crap out once but it had a life time warranty so that wasnt an issue. I couldnt figure out why it died though, think it had to do something with the angle i had it mounted. Ive since changed the angle on my new one and havnt had a problem since in 6 months and i drive it everyday.
  4. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    im running a holley blue...its perfect with a 2-5psi regulator
  5. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Well, I use a cheap faucet "vibrator" pump. The square one. It works great and definatly has enough flow for you.
    I use a holley pressure regulator. Dont know if it even works but whatever. (no guage)
    DONT buy a summit fuel pump. Worst $108 bucks ive ever wasted. Louder than the stinking exhaust. :doah:
  6. KEKAHA_HR
    KEKAHA_HR Member
    As stated, mechanical fuel pump is fine. If going electric, carter fuel pump is the best. It will last forever!
  7. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    i used the standard airtex fuel pump from auto zone......... i just had to replace it 1 year down the road. fairly quiet and gave a good constant 6 psi unregulated....... me personally if you go electric........ carry a spare pump you can swap out in a pinch. :waytogo:
    had i of done this it would have saved me 1 hour or runnin to the parts store to swap it out.
