What is this? 71 hilux
Discussion in 'Engine/Drivetrain' started by krazyasslunatic, Sep 6, 2009.
  1. krazyasslunatic
    krazyasslunatic Enthusiast
    Oklahoma
    1971 Hilux
    Just curious, in the corner of my bed on the drivers side, the corner by the cab, there was like a metal cover held on by 4 bolts, I removed it and theres like a little box behind it and theres was like little fuel filter kinda deal but its only had a hose running from the bottom of it to a like small container mounted beneath the truck (looks like a small gas tank but it isnt) then on the other side there like a hose that runs from the fender tub in the black box.
  2. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    So this hose runs in a loop to different boxes within the truck? almost sounds like a vent for the tank or to catch unwanted crud like a oil catch can. Does it run to the tank or anywhere else?
  3. krazyasslunatic
    Oklahoma
    1971 Hilux
    not really a loop, one hos runs through the bed from this box to the little tank under the bed , there a hose that comes out into the bed that connect to this fuel filter looking deal, then theres 2 other hoses that runs else where, I took it apart and clean it and found it its some kind of emissions deal
  4. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    Sounds like a canister for the evap system. thats probably what it is.
  5. swapmeet
    swapmeet Enthusiast
    Your truck is a cali truck. Mine had the same thing. Its all hooked up to the gas tank to keep fumes from getting into the atmosphere. I took all mine out when I replaced my tank.
