What do you use??
Discussion in 'Off Topic' started by 91HiLux, Jul 4, 2008.
  1. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    Motor Oil?
    Engine Oil Filter?
    Engine Air Filter?
    Tire Brand of Choice?
    Spark Plugs/Wires of Choice?
    Tool Brand of Choice?
  2. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 22RE
    Motor Oil: Mobil 1 / Super Tech Fully Synthetic 10w30
    Engine Oil Filter: Napa Gold, aka WIX
    Engine Air Filter: Fujita F5
    Tire Brand of Choice: BFG brand
    Spark Plugs/Wires of Choice: NGK (both plugs and wires)
    Tool Brand of Choice: Snap-On
  3. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    1981 22r
    Motor Oil?...Castrol 10-30
    Engine Oil Filter? fram
    Engine Air Filter? fram
    Tire Brand of Choice? toyo
    Spark Plugs/Wires of Choice? NGK/both
    Tool Brand of Choice? craftsman
  4. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Motor Oil?...Royal Purple 20w50
    Engine Oil Filter?...Toyota
    Engine Air Filter?...K&N (cone type)
    Tire Brand of Choice?...Nankang
    Spark Plugs/Wires of Choice?...NGK/MSD
    Tool Brand of Choice?...Craftsman
  5. lownloud
    lownloud Toyotaholic
    Plains, Montana
    1987 Toyota 22R w/Weber 32/36 DGEV conversion, everything else STOCK !
    Motor Oil : Quaker State
    Engine Oil Filter : Toyota ( Mann Filter W712/38 )
    Engine Air Filter : Fram
    Tire Brand of Choice : More particular on specifications & ratings! Running Lexani tires now!
    Spark Plug : E3 Spark Plugs ( E3-46 )
    Spark Plug Wires : Taylor Spiro-Pro 8mm ( Taylor 77650 )
    Tool Brand of Choice : Don't matter to me, If it works & doesn't fall apart, I like it !
  6. trap
    trap Addict
    orange county ca
    92 pickup
    Motor Oil? mobil 1 synthetic
    Engine Oil Filter? oem toyota
    Engine Air Filter? k&n (downey off road air intake)
    Tire Brand of Choice? toyo proxies
    Spark Plugs/Wires of Choice? NGK iridium and magnacore
    Tool Brand of Choice? snap on ... matco some days.
    __________________
    only the best for my yota... and oh man does it get expensive some times.
  7. TRDer JOE
    TRDer JOE Newbie
    Bakersfield
    '92 Std Shortbed
    1992 22RE
    Motor Oil: Castrol Syntec 10w/40
    Engine Oil Filter: Fram Tough Guard
    Engine Air Filter: K&N cone
    Tire Brand of Choice: Falken Ziex
    Spark Plugs/Wires of Choice: Bosch Platinum quad tip
    Tool Brand of Choice: Anything descent
    Does the OEM oil filter perform better than Fram,Mobil1, etc..?
  8. trap
    trap Addict
    orange county ca
    92 pickup
    the cheapo fram filters have been known to leak back dirt into the motor, I have read the tough gaurd ones don't have this problem .. but they are just as expensive as the mobil 1 or k&n
    The mobil-1 uses a synthetic filter element which is probably better then the oem toyota but it costs twice as much
    The k&n uses a synthetic element, I think you can even get a chrome finish and it has a bolt on then end to crack it loose which is cool... expensive but cool
    the oem toyota has a much better track record then the fram , its cheap (5 bucks from the dealer), and it came with the motor in the first place. I hate going to the dealer, but if I am there anyway and I need a oil change (not by them) I pick one up
  9. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    Napa Gold filters are good too, they are made by WIX.
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Castrol GTX 20/50
    K&N oil & air filters
    Magnecor plug wires
    NGK plugs
    :cool:
  11. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    Motor Oil?
    Castrol Syntec 5w40
    Engine Oil Filter?
    K&N
    Engine Air Filter?
    K&N Cone filter
    Sumitomo Htrz II
    Bosch platinum +4's (not sure about these but they work)
    8.5mm magnecor wires
    Crafstman
  12. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    Spark Plugs/Wires of Choice: NGK wires, ZEX 4cyl Spark Plugs
    The ZEX spark plugs work great!! Engine runs very well on these plugs!
  13. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    22r carb'ed
    motor oil: royal purple 5w-40
    engine oil filter: napa brand
    engine air filter: DOnt have one its DUAL CARBS just air horns
    tire brand of choice: KUMHO
    spark plugs and wires: alcatron 8mm and NGK racing plugs
    tool brand of choice: SK,Snap on,Craftsman,Matco,Cornwell, and other brand cheap and good. what ever i can afford at the time.
  14. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    going to be switching over to AMSOIL 10w-30...
  15. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    75-80 20r's and 22r's
    Motor Oil? generally cheapest, but when it counts castrol gtx
    Engine Oil Filter? wix (note i use the chev 350 one)
    Engine Air Filter? k&n or weber k&n knock off
    Tire Brand of Choice? used
    Spark Plugs/Wires of Choice? NGK n NGK blue 8mm
    Tool Brand of Choice? craftsman/harbor freight
  16. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Motor Oil - Mobile 1 10w30
    Engine Oil Filter - Genuine Toyota
    Engine Air Filter - K&N
    Tire Brand of Choice - Anything with tread left
    Spark Plugs/Wires of Choice - NGK allround
    Tool Brand of Choice - Snap-On
    :D
  17. Harbinger
    Harbinger Newbie
    Kev....what up bro.
    how about Castrol GTX
    K and both for precleaner and air box
    Ac delco
    MSD
    Oh didn I nhot mention my toy has a 350 in it..SOrry you knew that. Peace
  18. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    Whats up Izzy??
  19. 1hightoy
    1hightoy Newbie
    nj
    3.0 V6..........
    Motor Oil? synthetic / use different brands.......
    Engine Oil Filter? fram filter.........
    Engine Air Filter? k&n filter......
    Tire Brand of Choice? mickey thompson........
    Spark Plugs/Wires of Choice? use toyota...........
    Tool Brand of Choice? craftsman........
  20. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    1982 2wd Hilux
    Motor Oil? Shell rotella 10-40
    Engine Oil Filter? Wix
    Engine Air Filter? na
    Tire Brand of Choice? What ever is on special
    Spark Plugs/Wires of Choice? NGK/MSD
    Tool Brand of Choice? It's not the tools, it's the hands that hold them...Seriously tho, what ever I can afford. Which means I have no snap-on or Sk stuff in my box. :D
