were can i get a lower ratio gearing for my rear
Discussion in 'Engine/Drivetrain' started by naputir, Apr 27, 2010.
  1. naputir
    naputir Member
    guam ft stewert ga
    1994 regular cab
    hi guys i just wanted to ask were can i get a lower ratio gearing for my rear from wat can i get it from thanks guy for the help
  2. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    partstrain.com and lcengineering has some but they cost ya best thing to do is get a new rear end
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    do you have the 7.5 or the 8.0 rear end? do you want lower (as in lower gear for more power) or (lower gear for more top end)??
  4. planemos
    planemos Toyotaholic
    British Columbia
    Turbo Toyota trucks (factory turbo) have lower gears because they had to compensate for less power. Well my Dad had a diesel turbo 4x4 and it had lower gearing.
  5. naputir
    naputir Member
    guam ft stewert ga
    1994 regular cab
    i want lower gearing for more power and its a7.5 rear end
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    MK3 supra has a optional 4.30 LSD 7.5 rear end that can be raided and put into your truck. :cool:
    I reccomend that you have a 5 speed with that deep gear.
  7. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    most 2wd 5 speeds ive seen have 4.10s in them. shonuff has 4.30s in his stock. any shorter than that and you need a 6 speed. my w55 in 5th (0.87:1) and 4.10 rears its still screaming if i go over 75.
  8. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    MK3 supras have 8" G series diffs. MK2 celica supras have 7.5" F series diffs. they can also be had with 4.1 and 4.3 diffs
  9. SEMichigan10
    SEMichigan10 Newbie
    I think you need to read this thread
