Weber 32/36 jumpy idle
Discussion in 'Engine/Drivetrain' started by yota89, Oct 24, 2014.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Hey guys need some help I've rebuilt my 32/36 used all same jetting
    But replaced all that the rebuild kit came with and my idles jumpy it will
    Idle smooth then jump my idle rides at about 750-800 and jumps up and down
    What can cause this thanks
  2. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Are you using a fuel pressure regulator? My guess would either be that, if you aren't using one, or a vacuum leak.
    Try spraying some carb cleaner around your carb adapter plates and see if the idle goes up.. The 2 piece adapter seem to warp really easy and then leak.
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Yup smells like a vacuum leak.
  4. yota89
    yota89 Enthusiast
    guam
    89 single cab
    no fuel regulator n im using the single one piece adapter..
    ill look for vac leak
    x2
  5. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Tried it all can't seem to get it to idle right stupid carb
  6. first80toyota
    Pacific Northwest
    '77 Hilux
    Try using a fuel regulator.. My buddy had the same problem of a jumpy idle and once he put a regulator on it fixed it.. We even called them up and they'd said that was there number one solution for most problems because most people don't use one
  7. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Yup most people dont use them on the 2 barrels cause its supposedly a stock
    replacent...ill try it out thanks!
  8. first80toyota
    Pacific Northwest
    '77 Hilux
    I don't run one, but I also don't have any problems.. Seems like some people do and some people don't need them
