Vacuum hoses?
Discussion in 'Engine/Drivetrain' started by josealex1636, Feb 16, 2012.
  1. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    I took the black thing were the air filter goes on the carb and the vacuum hoses that are underneath i think i switched dem up just wanted to see if you guys can help me route them to the right location thanx
  2. NavyMC
    NavyMC Member
    TN
    78 SR5
    Here is my experience with figuring out the vacuum systems... There are many variations (in my opinion) of the systems and your best bet is to look at the diagram located under the hood. I know, not much help... but when I went a searched for the vacuum diagram for my 78, I couldn't find a picture for my little gem of a truck and then I realized it was under the hood all along. Also, the monkeys that had the vehicle before me didn't have a clue about the vacuum system and I surmise they used the wrong picture because when I got it pipped correctly in accordance with the diagram, I had three extra feet of tubing! AND I was able to get it to run correctly!!! So check under the hood and if not look in google images... There are quite a few there but make sure its the right application... That particular piece you are pointing to sets up the hot air intake (if I am not mistaken) for when the engine is cold so not much worry there as long as the vacuum is available to the component you are pointing at...
    cheers!
  3. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Oh alrite bro thanx nd yea cuz i was looking at da diagram nd didnt understand it
  4. NavyMC
    NavyMC Member
    TN
    78 SR5
    Take a picture of it brother and post it. There are a TON of folks on here that have "been there, done that" and can explain every little nuance! Post the picture of it and see what happens. I have all the literature for a 78 and I don't think much changed with the terminology of components... Post a pic....
  5. josealex1636
    Ontario,CA
    83 Toyota Pickup
    U mean of the emission label? I have a pic but since its old its kinda hard to c
  6. rockman122602
    rockman122602 Newbie
    williamston, south carolina
    93 toyota base
    I need a vacum diagram for a 20r engine. I am swaping a 20r and taking out a 22re engine that is bad.
  7. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Jose,
    The 1st two pictures actually look correct. Is your truck running any different?
    Rick
