urthane bushings
Discussion in 'Suspension/Chassis' started by pig rig, Mar 11, 2012.
  1. pig rig
    pig rig Enthusiast
    bow washington
    so anyone got a quick way to pull the stock bushings out of the lower control arms so I can put urthane bushings in?
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Plan to waste several hours of your life.
    Cussing, throwing things, then getting frustrated and blow torching them out...
    Have fun!! :nana:
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Run a sawsal on the inside of the bushing until you cut through it,than it will just drive out.
    Be careful not to damage the arm!!:cool:
  4. garagedoorman
    garagedoorman Addict
    north georgia
    I've never had a problem. I drop it off at the machine shop... Pick'em back up later. Piece of cake:)
  5. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I had to use a tourch to get mine out..major PITA. Worth it though.
  6. pig rig
    pig rig Enthusiast
    bow washington
    for the lowers I made a press out of a chunk of 2" pipe and flat bar and used a piece of all thread as a jack bolt to pull the old one out and shove the new one in
    the upper I ended up putting the torch to it. it made it easy but messy
    the drivers side took me about 5 hrs and with the building of a press I should be able to do the other side in a few hours we'll see tomorrow if I get time
  7. biketrials25
    biketrials25 Member
    Charlotte, NC
    1980 Hilux
    Where is a good place to source urethane bushings kits?
  8. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    @ biketrials25 - go with Energy Suspension bushings
  9. kart_tech
    kart_tech Newbie
    Hesperia, Ca
    1986 sr5 x cab turbo
    just did complete urethane set front and back....OMG what a difference. Since the center sleeves have to be reused and outer shell, drill holes side by side through rubber, punch out. clean out with a rat tail file. BURNING RUBBER....not my lungs.
  10. jjsjjsva
    jjsjjsva Newbie
    Did you install the poly bushings into the leaf spring front eye loop as well? If you did, then can you answer my question?
    I have a 86 sr5 x-cab non-turbo and installed poly bushings in the rear shackles. It was very easy to do. I was going to install the poly bushings from the kit into the front eye loop ,but wasn't sure if the whole OEM bushing needs to be removed including the steel sleeve, or just remove the OEM inner rubber part of the bushing?
    Thanks.
    I called Energy and they flip flopped on me and said could be either way depending on the truck.
    If you did install th
  11. CREETIN247
    CREETIN247 Enthusiast
    Columbus, OH
    86 Std
    Go to most auto parts stores and rent a control arm bushing puller!!! It'll prob be about $120-$150 to rent but you'll get your money back when you return it. TRUST ME!! RENT THE TOOL!!! :waytogo: As for to new bushing I just swapped mine out with MOOG LCA bushings and literally ALL the others with Energy Suspensions. You'll need the original outer LCA bushing sleeve if you get the ES, and to keep the outer sleeve you'll have to torch to soften the bushing and then drill holes on both sides over and over to loosen it enough to get the center sleeve out and then the old bushing. Honestly easier to just rent the tool and replace the whole bushing!
  12. trying2learn
    trying2learn Newbie
    Citrus Heights
    88 pickup 22r RWD longbed deluxe model
  13. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Energy Suspension
  14. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Everyone makes a big deal about this but I've never had a problem?
    I just heat up the metal sleeve on the outside(not torching the rubber) until the rubber basically melts on the outside and then slide it on out.
  15. yotarip
    yotarip Veteran
    LOL. I didn't even use a torch. Just a cheap harbor freight hot air gun set to max. With enough time it would burn through the rubber. The $15 hot air gun lasted just long enough to complete the install.
  16. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    Yes, I bought the prothane kit. Comes with everything on the stock suspension. So if you upgraded from the stock sway bars, you will need to buy different bushings.
  17. trying2learn
    trying2learn Newbie
    Citrus Heights
    Ok sweet Frinzo thanks, I'm stock so far, looking to drop in the future though. I'm saving for rear lowering leafs and drop spindles for the front. Should I buy the bushings and just wait till I do the drop to install them, or should I install and then buy bushings because the new parts might be different?
