I can not get my turn signals to work. I put my old tail light back on, replaced every bulb and no luck. The brake lights work, the tail lights work, the reverse lights work and I replaced the fuse. Does anyone have any other suggestions?
+1..or wiring, could also be your hazard switch, I can't remember if its just the turn signals or everything but if the hazard switch is not plugged in or working it will cause lighting issues
Hum It is possible that i did not plug in the hazard switch. I am not sure where to find the flasher module or the multi-function switch on this little pickup. Where are these located?
I looked at the hazard switch and it does look like it is unplugged. Damn that means I need to pull the dash apart again. I could not see the connector to it.
I took them out because i wanted to try and eliminate everything i changed. They are going back on today hopefully. Now that i know what the problem is i will be putting the altezzas, clear corners, and clear bumper lights on. Do you know what the Idaho law is for light color for the bumper and corner lights? I do not want the yellow color at all?
