Truck needs new suspension (race prep) what are my options?
Discussion in 'Suspension/Chassis' started by NashMan, Feb 10, 2013.
  1. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Well I have been looking but hard to find stuff with out 4x4's popping up and slammed trucks.
    I came across this company SWAY-A-WAY - axles, torsion bars, and shocks for trucks, cars, and off-road vehicles - Torsion Bars
    they seam pretty pricey 600 for set of t bar's :jawdrop: or 200 for the other set :confused:
    Then there's bell tec sway bars but herd the rear sway bar does not fit ????
    is there better sway bars out there ?
    and last but not least doing coil over swap in the front
    all in all i don't want to spend to much money i have looked around but time to ask around time
    give me nice big fat list to look form to would be nice
    Thanks
  2. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    first, what type of racing are you doing?
    if its street/track you will not need the 300m (#31636) sway a way torsions. they are for log travel desert racing trucks and will be incredibly stiff on anything else. the #1636 will work on stock length arms and will have an increased spring rate. if you can find them used, downey also used to make upgraded torsions about the same as the sway a ways.
    doing a proper coilover conversion can get pricey too depending on who you go with for shocks and springs and there is a lot of options out there too. single, or dual rate. non adjustable dampening, 1 or 2 way adjustable. reservoir or non. then you have to figure out the fab work to mount the setup and get enough clearance for the coilovers to fit. there is not really going to be a bolt in kit for this.
  3. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I run 2" drop spindels and 3" belltech drop leafs, sway a way t bars and hellwig sway bars and my truck handles great. If you look around you can fimd new and used. My setup right around 1k for all of it. You get what you pay for. Just search and you will find good deals.
  4. NashMan
    NashMan Toyotaholic
    94 2wd
    Hot lap and auto cross and downey is no more ): I just wish they told the spring rate
    Coilover setup would be a set of qa1's or some thing like that since there cheep for what they are but there not a gas shock if remember right.
    fab work for me is no big deal just get tube bent then weld plate for ball joint ect ect or run set of a djm lowers for more room for coil over.
    Da roach how do you like the be tec drop leafs ? and did you still run an over load ?
    reason why I ask is I can get bell tec stuff for dirt
    and do you have pic of your truck ride height too
  5. Da_Roach
    NOVA
    I love the drop leafs. Rides way better them blocks and with kyb out back its very smooth. I will post up some photos when i get home.
  6. Beefed Taco
    Beefed Taco Addict
    When I see the word race, my mind immediately goes to coilovers. :waytogo:
  7. NashMan
    NashMan Toyotaholic
    94 2wd
    well my one question that i really want answered is this bell Tec rear sway bar issue whats wrong with it ????
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I'm running the sway aways got them used but they did make a good bit of difference combined with my shocks and poly bushings and end links up front maid a vast improvement .. I used to end up in the passenger seat of my truck after a run ...I say there worth the money.
  9. NashMan
    NashMan Toyotaholic
    94 2wd
    well all have to find dealer that sells them and get a price quote
  10. NashMan
    NashMan Toyotaholic
    94 2wd
    A new question
    is it true that djm lower control arms allow more room for a coil-over
    if not I can just get a set a drop spindles
  11. Robert m
    Robert m Addict
    Apple Valley, Ca
    to me, it seems like you would have the clearance problem with the upper arms, not the lowers.
  12. NashMan
    NashMan Toyotaholic
    94 2wd
    well thous will be tube just I wana have the longest shock body I can run for more oil
    they are most likely the same and should be, but some pic's that I look at showed there sit lower down and could fit a longer shock ?????
