Transmission?
Discussion in 'Engine/Drivetrain' started by Zombie Monarch, Oct 2, 2011.
  1. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    This is a pretty simple question; What transmission came stock on the 22re's 2wd, in 91? The noise mine has been making is getting a lot worse and is falling out of 5th so I think it's time to look into a new one..
  2. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
  3. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    G Gode Transmissions
    N10010
    R Code Transmissions
    N10012
    Toyota uses the following transmission codes. Please carefully identify...1984-95 G52-G54, G58, and W56 (most 4 cyl) 1986-95 R150 F and R-151 F (turbo and V6).
  4. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    My 88 shows a G57. I don't hear or read much about it ??? Any insight on it ?
    22R88
  5. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Mine's got a W56, it's pretty common.
    G series are just lighter, less beefy versions of the W series AFAIK.
    I've got lists of gearing for the W5x series and some others if you care.
  6. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    99.9% sure it's a W55. If the speedo cable is on the drivers side it's a "G" series trans. "W" series is on the pax side. I doubt it will be a "R" series since they only came on the 85-88 turbo 22re's, V6 models and the turbo supra...
    It should tell you on the data plate sticker affixed to the door jamb...
  7. IronNam
    W58 swap. use your truck's shifter... hhehhehehehe
