Transmission questions
Discussion in 'Engine/Drivetrain' started by vettelover, Nov 14, 2014.
  1. vettelover
    vettelover Newbie
    Gilbert, AZ
    1994 22re 5speed
    I have been researching tranny options and have come accross some things that I can not get answers for.
    My 1994 pickup has a W55 tranny.
    The W58 would be a virtual straight accross drop in with a little bit of work.
    What about the R150/R154 trannys? I have a friend that is running an R154 in his IS300 making well over 500whp and it holds without any issues.
    Questions:
    Will the R150 swap straight over?
    How much hp/tourque can the W55 hold reliably?
    Is the R150 the same length as the W50/55 series trannys?
    Everyone seems to use the W55 trannys and not the R15X series transmissions so I'm curious. I'm asking because I don't have a W55 and R154 to sit side by side to check myself. Any help would be greatly apreciated.
  2. jetas
    If i remember right you can use the gm trans if you swap the bellhousing for the toyota one. Think you need an adapter for it though
  3. vettelover
    vettelover Newbie
    Gilbert, AZ
    1994 22re 5speed
    Are you talking T5 or ZF6? Id like to not have to change the drive shaft if possible.
  4. jetas
    700R4 is the swap i was thinking of
