Transmission leaking
Discussion in 'Engine/Drivetrain' started by yota4life, Apr 25, 2011.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    So my trany just started leakin pretty bad it looks like it's comin from the back of it or the speedo cable. I have the 22re with 5 speed. I was wondering where I could order the rear seal for the trany
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    its a pretty common seal. check the local auto zone.
    make sure you check your speedo plug in at the trans to see if its not loose.
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    What kinda transmission do I have? Is it the w55?
  4. SD YOTA
    yea..... w55.
    the speedo attaches to a sensor in the trans mission or if cable driven, a gear type actuator. this sensor or gear drive will have a o-ring that might have gone bad (if it is in fact leaking from there) when you go to replace the rear seal, unplug the sensor/gear drive and inspect the o-ring.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ok just makin sure it's the w55 I'm lookin into buying a new one when I buy my new motor. But I wanna get this leak fixed before. I'll check the o ring on the speedo cable it might be from there cause I took it off to see if it was hooked up an I put it back in but I'll double check tht tomoro
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Does anyone know what the bushing is called on the rear of the trany where the driveshaft goes into
  7. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
    Are you talking about the transmission mount?
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    No not the mount I read tht there's a seal or something tht could be leaking. An I think thts where mines comin from
  9. lionsftb52
    lionsftb52 Member
    Orange County, Ca
    1994 toyota pickup
    check your trans mount while your at it. that was the cause of my leak. just my 2 cents
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I'll have to check tht out aswell. Anyone know the name of the seal for the end of the trany?
