Tps removal help!!!
Discussion in 'Engine/Drivetrain' started by TSLUX, Jan 10, 2010.
  1. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    how can i take out the tps of a 22re motor without taking off the manifold?
  2. IronNam
    its on the throttle body itself.
    remove intake tube
    remove TB from manifold (3 bolts and 1 nut)
    go for it
  3. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    thanks, i did it but the tps was a different fitting.
    i have a 22re and wrenched off the other tps from a 22re also but it was different. how many different tps's are there for 22re?
    my plug is squarish and the other one is roundish.
    are there any differences?:shrug:
  4. IronNam
    what year of 22RE did you pull it off of? it may be from an older 22RE.... :[
  5. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    pics would help....mine is square and i have a 91..i just removed the throttle body because it makes it allot easier to adjust the TPS when you put the new one on
  6. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    sorry i dont have a camera at the moment, but i do think it changed after years, i have a 90. idk what year the other 22re was.
    i thought it was just plug and play but when i looked it up, the tps is really technical. any tips?
