torque specs needed asap
Discussion in 'Engine/Drivetrain' started by JOE_1985, Jan 22, 2010.
  1. JOE_1985
    JOE_1985 Veteran
    87 custom
    ive missplaced my book and im trying to finish putting my 22r back togather that im putting in my 87 truck
    i need the specs for a 89 22re engine for the following
    rod bearing cap nuts
    timing chain tensionor bolts
    oil pan bolts/nuts
    timing chain guide bolts
    water pump bolts
    oil pump bolts
    head bolts
    intake nuts
    exaust nuts
    trying to get my truck going by mid feb
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    rod bearing cap nuts: thru 85: 46 ft-lbs, 86: 43 ft-lbs, 87 on: 51 ft-lbs
    timing chain tensionor bolts:?????
    oil pan bolts/nuts: 9 ft-lbs (1985 and newer), (79-84 4.5 ft-lbs)
    timing chain guide bolts:?????
    water pump bolts: my book only show the v-6 spec of 13 ft-lbs i'd imagine its pretty close to the same
    oil pump bolts:
    bolt A (the one at the top of pump, requires some sealer) 18 ft-lbs
    bolt B (the longer bolts {left-middle, and top-right}) 14 ft-lbs
    bolt c (the two bottom bolts) 9 ft lbs
    head bolts: 58 ft-lbs
    intake nuts/bolts: 14 ft-lbs
    exaust nuts/bolts: 33 ft-lbs
  3. JOE_1985
    JOE_1985 Veteran
    87 custom
    ok thanks im going to try to have a "long block" in a week or 2
    also im going to add a pacesetter header from my celica and a trd stage 1 cam, should wake up the engine abit till i put the 32/36 on
