I have to fab some lower control arm that will work with the spindles Im using. Its binding on drop and lift...
Put on a New head gasket, Cleaned up the Pistons and the cylinder head. no more carbon buildup in there. New Timing Chain and guides with sprockets. New oil etc. Pics are in my build thread.
Tried to removed the ball joint end of the pitman arm so I could swap out the steering box - and couldn't get it off!!! Even with a BFH!!! I even tried my 5lb sledge and a drift, no luck. Borrowed a puller, we'll see if I break it
should've just added a resonator and route it out the back.. would've sounded better. what muffler you running?
