DF7AF8E9-1FB5-46F3-B721-6008CB63712C by mr-bubble66 posted Jul 5, 2018 at 9:24 PM AF5BEE55-5E8C-4467-9E18-EF73A569FD52 by mr-bubble66 posted Jul 5, 2018 at 9:24 PM It has some pretty rough surface rust so I think it’s be a good idea to paint ? What do y’all think ? And what have some of y’all done to fix a rusted out floor where the cab mounts ? Also some little holes in the bed
I like the look of the original paint, you can kind of see the stripes still which is cool. At the end of the day its your truck though!
Most of that is plastidip that the PO did the original is the rust stained white and the hood and roof are turning to a more ruff rust
If you don't keep it garage kept, then you'll want to deal with the rust before it eats the panels. While this answer sucks, sand blasting will give the best result. paint stripping wheels for grinders do a good job, but they wear quickly. the rust really needs to be gone before you can repaint. Then you can do a good metal prep (eastwood or por15) and rust encapsulator (primer with zinc). just another thought: primer is not a sealer. so if you clean it up and spray primer... don't leave it in primer. primer is porous and will hold water and you'll have the same problem after a few rains.
Yeah I don’t think I have much a choice but to repaint . Is anyone making the stripes for this year truck I like the rn28 decal
The passenger sides pretty rough I’ll get some pictures tomorrow I haven’t gotten a good look at the driver that rubber they have glued is really on that side
Check the area under the raintray. I had a leak there and caused rust to form around the cab mount as well. Thankfully I found a rustfree cab and used that to cut and weld in new metal. I've considered just covering he opening in the raintray so this issue never happens again.
51DED290-217E-42FD-B19E-524CA457417B by mr-bubble66 posted Jul 24, 2018 at 3:38 PM DD8FF34F-D1D6-49E8-B093-2B599BDE886C by mr-bubble66 posted Jul 24, 2018 at 3:38 PM This is the damage and I wish I could find a parts truck for it but I barely found this one haha
