Throttle body rebuild??
Discussion in 'Engine/Drivetrain' started by Live42day90, Nov 9, 2018.
  1. Live42day90
    Live42day90 Enthusiast
    Long Beach
    1995 Pickup
    is there a way to do this on your own? If so is there a kit or directions? Also anyone know of a website that has new ones other then lce they are on backorder
  2. Clay
    Clay Member
    Ohio
    93 Pickup
    What exactly are you trying to rebuild? the sensor itself is non serviceable. The TB on the 22re doesn't have much to rebuild on it.
  3. RAS671
    RAS671 Member
    The sensor of which you mean the TPS isn’t serviceable BUT you can definitely calibrate it if you’re not scared and have patience. The slightest degree can make huge impacts. Good or bad, depends how you tune.
    As far as rebuilding your TB, it really is just cleaning it and replacing the gasket. Otherwise, you could bore it out to have better throttle response, but you gotta know what you’re doing. I got mines off a friend who got his off an RET.
    Check 22RE Performance, not everything you upgrade or service has to be from LCE. Those are guys are solid and much more affordable pending what you buy.
