My 94 Yota 22RE gets about 13 MPG in the city with normal driving. I do have 18's on the truck but I believe I still should get better gas mileage. Plugs, wires, and distributor was changed in Jan. Any suggestions other than getting a Prius? Im still thinking about Sea Foaming it.
My first suggestion is fuel filter. Alot of people over look those. Found out mine had 168k on the original filter. Ran a TON better! Second suggestion is possibly the mass air flow sensor. Mine is goin bad and it is effecting my milage a little, but not like yours. I could be wrong on the air flow sensor. I'm not a mechanic, just goin off what my bro-in-law told me, and he is a mechanic.
jeez that's bad. what else has been done to it? hopefully the VAFM hasnt been touched by the previous owner. injector cleaner if it hasnt ben done in a long time.
maybe a stupid question but are you going off of your mileage on the truck? is your speedo off cause of your rims?
ya actually i didnt mean to quote at all, im on our stupid work computer and for some reason everytime you click reply it quotes....any how ya. lol
could be your o2 sensor... mine was bad and never set off a light... do you know if your check engine light bulb is still good... to test hop in the truck and turn your truck to ignition... it should come on for a couple seconds... if you dont see it... its time to replace the bulb..
yup definately fuel filter! maybe a clean air filter. and prob might wanna claen the throttle body with some cleaner, i bet its all junky and what not in there, also maybe youve got a clogged cat and yea definately clean those injectors.
